Windshield Glass?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lucky13Taco, Mar 27, 2014.
  1. Mar 27, 2014 at 8:19 PM
    Lucky13Taco
    Lucky13Taco [OP] Member
    Tulsa, OK
    2013 Tacoma SR5 TSS
    2inch lift,Nitto trail grapplers,18inch murder wheels,nerf bars
    Today I noticed an eight inch crack on the passenger side just left of my rear view mirror. No rocks or debris hit it....Is this still covered under the manufactures warranty? Defect?
  2. Mar 27, 2014 at 9:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The dealer might play ball with you, but I highly doubt it.
    I know that I would say no, because something hit your windshield. Glass doesn't spontaniously crack.
    How are you claiming that it was a factory defect?
    What are you basing it on?
  3. Mar 28, 2014 at 5:09 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    It's a '13, there is almost no chance the windshield can just crack on it's own or due to a manufacturing defect. Just doesn't happen. I doubt Toyota is going to accept it as a warranty item.
  4. Mar 28, 2014 at 6:35 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Riding around with the defrost on and it being cold outside. Will "spontaneously" crack it
  5. Mar 28, 2014 at 6:42 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Could be an insurance claim.
  6. Mar 28, 2014 at 6:52 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Post a pic of the crack where it starts and Ill take a look at it.
    Oh really...........And your expertise in this field is?
  7. Mar 28, 2014 at 7:16 AM
    XXXX
    sKiP
    05 Prius
    I have a feeling many Tacoma owners have had defective installations and Toyota simply covered this up because there aren't many people like us who specialize in glass.
    I know I did. My crack started from the edge and "ran" when I turned on my heater when I had a ton of snow on the outside of the glass. It did not "run" from a chip.
  8. Mar 28, 2014 at 7:24 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Recently had a cracked windshield incident on my '14. I contacted Toyota and was told their warranty doesn't cover glass. (You can buy glass coverage from multiple sources if you choose to.)
  9. Mar 28, 2014 at 8:01 AM
    jethro
    Geoff
    Southern NH
    So did Toyota replace it under warranty?
  10. Mar 28, 2014 at 8:05 AM
    Lucky13Taco
    Tulsa, OK
    2013 Tacoma SR5 TSS
    Thanks for the info guys. I took it to the local dealer and the manager wanted to use the "ball point test" to which it did not pass...go figure, so 3 days 100 miles into my first taco and I'm already having to replace a 1400 dollar factory windshield.
  11. Mar 28, 2014 at 8:24 AM
    XXXX
    sKiP
    05 Prius
    They "said" it doesn't cover glass, but it DOES cover manufacturers defective labor.
    You're not doing it to frozen glass though :D
    and you need to stop doing that man! I know a guy who almost died when the flame chased back to the bottle. He is horribly disfigured. At my old job we used heat guns and man did that suck....took 10 minutes to heat it up. Now we use tape measures. If you have a fat max and it goes bad cut it in lengths about 5-10" long and taper the edges. It will cut the inter-layer perfectly every time and keep your fingers farther away then a razor blade.
    I never notified Toyota. It started at the bottom under the blacked off portion and ran about 10-15" across then back down so it wasn't in my vision and I wasn't about to waste my time fighting Toyota over a $165 windshield. I have AAA so I just had them replace it because they warrant them for 1 year.
    Please explain this test to me? I'm a 3rd generation glass guy with over 20 years experience and never heard of it...:confused:
  12. Mar 28, 2014 at 9:27 AM
    1of7627
    Mark
    Post Falls, ID
    If it wasn't visibly broken (and detected) when you bought it, it's not covered.
  13. Mar 28, 2014 at 9:36 AM
    XXXX
    sKiP
    05 Prius
    I'm not going to argue... I don't have my warranty info on me nor do I care to ever look it up tonight when I get home. Heck I never even said anything to them when it cracked.
    I just know every warranty I have ever read in my entire life covers faulty labor.
    Ill believe you if you post the warranty exclusion.
  14. Mar 28, 2014 at 10:02 AM
    chickdr
    chickdr Well-Known Member
    Atlanta, GA
    Tacoma 2.7l
    $1,400? They are scamming you. As said above the glass should be under $200.
  15. Mar 28, 2014 at 10:38 AM
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
    That sucks man.. I'm getting a new windshield Monday for the same reason. a 4" crack appeared on Monday and has since grown to 10" or so.. right from the bottom middle. I can see a small divit where a rock hit it in the black edge border. :mad:
  16. Mar 28, 2014 at 10:47 AM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    Post the price so the owner of this thread knows how much they are getting screwed with a $1400 bill
  17. Mar 28, 2014 at 10:52 AM
    khx73
    Saint John NB, CAN
    I will... insurance will cover it, minus deductible. But I'll make sure to get the full price to post.
  18. Mar 28, 2014 at 2:27 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
  19. Mar 28, 2014 at 3:24 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Same in MA
    CC
  20. Mar 28, 2014 at 9:00 PM
    Lucky13Taco
    Tulsa, OK
    2013 Tacoma SR5 TSS
    The "ball point pin" test is where they run a pin down the crack and if it catches then it is not covered under warranty.I should clarify its 1400 for toyota glass and 350 for some random guy to come to the dealership and replace with aftermarket glass. My deductible on ins is 500 so I'm well below them paying for it. :) ready for summer in the taco
