Windshield nozzle issues - warped hood ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AsianTaco2017, Mar 22, 2024.
  1. May 5, 2024 at 10:28 AM
    #41
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's probably better answered by a body guy, but i believe the technique uses pry bars and hammers to 'massage' the metal to where it should've been
  2. May 6, 2024 at 5:48 PM
    #42
    soundman98
    NW Indiana
    what do the squirters look like with the hood closed?
    i really think you're looking at the wrong half of the hood. the front edge isn't going to affect the squirter direction at all, where the rear half is what sets the angle. specifically, i think the metal work i'm imagining is in the underside of the hood structure, where the squirter clips to the hood assembly.
  3. May 6, 2024 at 5:51 PM
    #43
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    there are three different part numbers of nozzles as they explained one is a 0° is a +1° and the other is a -1°
  4. May 6, 2024 at 6:34 PM
    #44
    Morrist1992
    Morrist1992 Active Member
    Tyler
    2023 Tacoma OR Lunar Rock
    I get that - But I'm just out of idea's since everything else looks normal to me. The underside of the hood also looks fine to me, I can't tell a difference from left to right to in the middle. Nothing stands out to me that would be causing any of this.
    I'm hearing ya man, but IDK wth that means, lol. That doesn't make any sense to me.
  5. May 6, 2024 at 6:37 PM
    #45
    Morrist1992
    Tyler
    The wiper nozzles also look the same to me with the hood down. I don't notice any difference. Apparently I'm not the only one confused by this since the body shop still hasn't fixed this...
  6. May 6, 2024 at 6:42 PM
    #46
    soundman98
    NW Indiana
    i'm actually wondering if the rubber weather stripping on the hood cowl is interrupting the stream, and they're adjusting the squirter front/back to clear that weatherstripping...
  7. May 6, 2024 at 6:55 PM
    #47
    Morrist1992
    Tyler
    It's possible - I'm willing to believe anything at this point. However, if you look at the picture I posted where the wiper fluid is puddled up, a lot of it is dripping from the underside of the hood where the lip is. That's what has me thinking the hood is just sitting way to low on that back corner or something.
  8. May 7, 2024 at 4:24 AM
    #48
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    OK, so think for this way. The nozzles for the windshield washer sprayers are not adjustable. There are three different Part numbers that allow for the adjustability of the spray. The way that is done is by changing the spray nozzle itself. If the spray pattern needs to be higher, the plus one is installed if the spray nozzle needs to be lower, the minus one is installed.
    Morrist1992[QUOTED] likes this.
  9. May 7, 2024 at 4:25 AM
    #49
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    there is no adjustment for the squirter as you call them. They clip into a cutout and the lower side of the hood.
  10. May 7, 2024 at 7:42 PM
    #50
    Morrist1992
    Tyler
    Okay, now that makes sense. I wasn't understanding each one was an actual different nozzle. If that's the case then, why would they have put the incorrect one on the truck when being built? You'd think they would know which one properly fits? Also, why are they not all the same? There shouldn't be 3 different nozzles that fit the hood. It should just be one that works on all Tacoma's of that year.
  11. Jan 19, 2025 at 6:30 PM
    #51
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    Im having the same problem as the OP had . I had to have the windshield replaced and ever since , the pass. side squirter hits the bottom of the hood , it barely hits the windshield. I went out to do the needle adjust but could not figure out how to do it . Ill be running to the dealership tomorrow. This is the first vehicle i have ever had that you couldnt adjust the nozzles
  12. Jan 20, 2025 at 5:37 AM
    #52
    AsianTaco2017
    AsianTaco2017 [OP] Active Member
    Jeff
    2017 Taco SR5 Double Cab
    The dealer had to send my truck to an independent body shop to have it worked on. Fortunately, the shop had an identical Tacoma being worked on and they were able to compare the issue. I wish I knew exactly what they did but did not replace the hood. The repair has been good thus far. If you are curious, the body shop quoted $1500 if they were to replace the hood. This includes paint etc.
  13. Jan 20, 2025 at 12:57 PM
    #53
    GaMGMTaco
    GaMGMTaco Well-Known Member
    Billy
    NE Georgia
    23’ MGM TRD OR DCSB 4x4
    Anyone have the part numbers for the 3 different nozzles? I have a passenger side nozzle that forms a puddle on the cowl every use. 23’ TRDOR DCSB.
  14. Jan 20, 2025 at 4:11 PM
    #54
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I’m not sure this is what you are looking for but take a look at it.
    WINDSHIELD WASHER NOZZLE
    Part Number: 8538130220
    Supersession(s): 85381-30220; 853810K070
    This one is R Side (passenger side)
    https://autoparts.toyota.com/products/product/nozzle-fr-washer-r-8538130220
    GaMGMTaco[QUOTED] likes this.
