Windshield Washer Bottle
Discussion in '1st Gen. Tacomas (1995-2004)' started by RedlegETT, Jul 2, 2010.
  1. Jul 2, 2010 at 4:07 PM
    RedlegETT
    RedlegETT [OP] Member
    Las Cruces, New Mexico
    04 PreRunner Double Cab
    I noticed my windshield washer bottle on my 2004 Tacoma is brittle and leaks fluid, has anyone had this problem and how did you fit it? can they be ordered from the dealership?
  2. Jul 3, 2010 at 2:48 PM
    blitz10
    blitz10 Active Member
    I have the same problem on my son's 03. The cap was about $6.50, didn't order the screen. I did not know it was cracked in the upper neck area till installing the cap and putting fluid in it. I bet it is expensive, but will probably order it, I like things to work right.
  3. Jul 3, 2010 at 3:02 PM
    C17Guy
    C17Guy Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
  4. Jul 4, 2010 at 1:46 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I have that same problem on my 99. The neck is cracked and so is the lid. It doesn't leak fluid yet, so I'm not too concerned, and at the price they're going for a glorified water bottle I don't think I'd get a stock replacement...I think I'd rather retrofit a Nalgene bottle than pay $83 for a USED resevoir.
  5. Jul 6, 2010 at 2:52 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Go get fiber glass cloth and some fiber glass resin.
    Put the cloth over the hole or crack and apply the resin by brushing it on there.
  6. Jul 6, 2010 at 7:58 AM
    cadman
    cadman Well-Known Member
    Pensacola, Florida
    TRD PreRunner
    i have a crack on the filler neck, and repaired it by cutting a few strips of silver alumimum duct sealing tape. the metal tape not the cheap cloth stuff.
  7. Jul 6, 2010 at 8:09 AM
    02YotaGuy
    02YotaGuy Full Spectrum Off-Road, Owner
    Matthew
    Tucson, AZ
    05 Tacoma, 94 FZJ80
    Salvage Title Mod, bed rack tire carrier, Rago Fabrication Ditch Light & Bumper bar brackets, LED rock lights, 5100s, 887s, stereo stuff.
    I've had the same problem... But I think mine hppened when this fat old lady pulled out in front of me and destroyed my front end... So her insurance is going to fix it... I hope...
  8. Jul 6, 2010 at 2:21 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 5 lug LT
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, custom bumpers, sliders, bed cage
    Ive seen a few guys that replaced the assembly with a piece of ABS tube. Works well and opens up some space. Plus with certain bumpers this looks way better/ is more functional.
    I think Its somewhere on TTORA. Ill see if I can run into it here in a minute.
  9. Jul 6, 2010 at 2:31 PM
    Siebler
    CJ
    Portland, OR
    99 5 lug LT
  10. Jul 6, 2010 at 2:35 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    just get jb weld or silicone and put it on the cracks it will seal it
  11. Jul 6, 2010 at 3:47 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    you can get a new tank from the dealer! eeeesh i would be scared to go there a new cruise control cable was 104 bucks. thats a 18 inch cable! so im saying its a pretty penny.
    and i have the same problem with my tank. its cracking/ breaking. i want a new one but dont need a new one yet
  12. Jul 6, 2010 at 9:43 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Mine was cracked almost all of the way down. I just cut the bad part of the neck off and put duct tape over the whole. I will add a filler neck and screen soon though. :D
  13. Jul 9, 2010 at 8:35 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I took my washer jug out of the truck and used fiberglass cloth and resin to brace and seal up the neck.
    I tried to do it with the jug installed and it was a fail
    Came out nice when you can get at it and work the fiberglass like it should be done. I took strips of glass cloth about 2 in wide and soaked them in resin and then wrapped the strip around the jug neck from bottom to the top.
    Beats spending 71 $ on a new jug
    Looks like the failure mode is engine heat. the lower part of the jug was fine
