Windshield washer jets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kpinks, Dec 15, 2010.
  1. Dec 15, 2010 at 4:55 AM
    kpinks
    kpinks [OP] Active Member
    Kevin
    Ottawa, Canada
    Tacoma TRD Offroad
    For some reason, just lately, my windshield washer jets are not working, obviously because they are frozen or something. Has anyone else encountered this problem. I even store my truck in a garage.
    Thx
    Kev
  2. Dec 15, 2010 at 5:24 AM
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    It just dropped below freezing yesterday here in GA an mine haven't worked since. Still frozen maybe?
  3. Dec 15, 2010 at 5:34 AM
    reg boulette
    reg boulette Well-Known Member
    Use a small pin or needle on the jets to free them up. Noticed mine iced up a lot more quickly on this truck than other vehicles. Also, check hoses under hood for freezing.
  4. Dec 15, 2010 at 5:48 AM
    nhgranite
    nhgranite Well-Known Member
    N.H
    fisher plow
    use good washer fluid. rated at -20f at least.
  5. Dec 15, 2010 at 5:54 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I use the rain x with the antifreeze in it. No issues.
  6. Dec 15, 2010 at 9:31 AM
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    09 Tacoma
    I keep a poppy from Nov 11 in my truck for the wiper jets. Heat it up on cigar lighter and put the pin in the jets
  7. Dec 15, 2010 at 9:40 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    DO NOT STICK A PIN IN THE JET!!!!
    you will be buying new ones soon if you do that. get some de-icer spray, and some good antifreeze washer fluid, they also have additives for it for reallly cold climates.
  8. Dec 15, 2010 at 10:00 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    How cold does it really need to get? I've had my truck in -45ºC with -40ºC Rated fluid and I never had any issues.
    Unless you forgot to take the summer crap out this is a non issues.
    Not the jets fault.
  9. Dec 15, 2010 at 10:03 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Just dump some anti-freeze fluid on them...the same stuff you SHOULD be using in the tank. I really like the Rain-X anti-freeze with bead technology. It doesn't freeze and I don't use my wipers in the rain.
  10. Dec 15, 2010 at 10:05 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    ehh...only one of them is gay blue...we'll let them fight it out to see which is which
    we all know it's SGB
  11. Dec 15, 2010 at 11:51 AM
    nhgranite
    N.H
    fisher plow
    :brianr: i can only imagine witch one
  12. Dec 15, 2010 at 12:43 PM
    jhodge83
    SC
    :D
  13. Dec 15, 2010 at 12:56 PM
    nhgranite
    N.H
    fisher plow
    it will be satin black some day. :cool:
  14. Dec 15, 2010 at 1:57 PM
    TACOMA TRD
    Tom
    PA
    LOL...I just noticed... Well mine is passenger side, his is drivers.
  15. Dec 15, 2010 at 2:01 PM
    jhodge83
    SC
    and you have a manly blue:D
  16. Dec 15, 2010 at 5:20 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    First new 2010 I got, washer didn't spray, figured it just needed fluid, bought some, didn't help, finally noticed that the hose that goes to the jets (on the hood, underneath it, passenger side) had not been pushed onto a connector and it was disconnected, so it sprayed basically onto the ground. Check the hose connections from the tank to the jets... Also listen near the tank to see if the pump runs, a helper person is useful for that.
  17. Dec 16, 2010 at 1:36 AM
    reg boulette
    WTF???Bull shit - Have been doing this for 40 odd years, including 5 years in Canada's arctic....average winter temp -30 celcius, no problems. De-icer spray might work for door locks but will not work its way into ice frozen in tiny spaces.
    I like the idea above about heating pin on the cigarette lighter - thanks!
  18. Dec 16, 2010 at 1:57 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    the one on my driver side didnt work for a cpl days when the temps didnt get above freezin but yesterday parked out in the sun all day thawed it out and it worked fine
  19. Dec 16, 2010 at 5:15 AM
    kpinks
    Kevin
    Ottawa, Canada
    Tacoma TRD Offroad
    OK, I ran the truck in my unheated garage last night for about half-hour with the idea that once the truck warms up, maybe it will de-thaw the clog. There must be summer fluid in the bottom of the reservoir which is frozen. But now I don't know how to get it out of the reservoir?
    Thx
    Kev
  20. Dec 16, 2010 at 6:41 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I've notice that there are many opinions concerning this issue and most if not all have some merit. I agree that we cold climate folks should use washer fluid appropriate for the climate, the lower the freeze temp the better. However once frozen, thermodynamics comes into play, we just need to raise the temp of the fluid above it's freeze point. Your body temp is 98.6 and simply holding the fluid lines between your hands will thaw them, not necessarily the best approach but it will work to thaw, they will refreeze if you don't improve the quality of the fluid and flush out the bad. Using a hair dryer is even more effective. The chemical hand warmers that can be purchased at sporting goods stores can be used to apply heat to the lines. etc. etc. The best is to prevent it from freezing all together. Now if your in a climate that is extreme, just add a bit of denatured alcohol to the fluid, once you find the right proportion alcohol to fluid you should be fine. My experience washing windows in the northeast is a 50-50 mix of alcohol and water wont freeze but it could be different for you area. A mix of alcohol and water in the right proportion will not freeze either. Just my opinions and you know what they say about opinions don't ya?;)
