windshield washer light wont go out
Discussion in '1st Gen. Tacomas (1995-2004)' started by jflores5, Jul 13, 2010.
  1. Jul 13, 2010 at 2:50 PM
    jflores5
    jflores5 [OP] New Member
    Jackie
    Colorado
    2000 4x4 tacoma
    I just filled by washer fluid and my dash light does not go out, is there a way to reset that.
  2. Jul 13, 2010 at 2:52 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    black electrical tape
  3. Jul 13, 2010 at 4:41 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    replace the sensor on the bottom of the washer jug
  4. Jul 13, 2010 at 5:04 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i had this problem a couple years ago but it was because it was leaking from everyspot possible lol the hoses kept coming loose and pissing out all the fluid.
  5. Jul 13, 2010 at 5:05 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if you unplug the sensor in the windshield washer bottle does it go out?
  6. Jul 14, 2010 at 7:19 AM
    BRP27
    04 4X4 Tacoma SR5
    If the sensor closes the circuit on low level and lights the light then unpluging and having an open circuit would work. I was under there last week removing the jar and there was only one plug and it got the pump and the sensor, so ... You would need to cut a wire on the sensor to try it, but it should work.
    Black electrical tape!!!
  7. Jul 14, 2010 at 11:24 AM
    jflores5
    Jackie
    Colorado
    2000 4x4 tacoma
    I do have a small leak, so I bet disconnecting the sensor will work. I'll try that this afternoon and let you know. thanks.
