Windshield Washer sprayer works for short time and then Nothing
Discussion in '1st Gen. Tacomas (1995-2004)' started by badaboom, Jun 23, 2019.
  1. Jun 23, 2019 at 6:17 PM
    badaboom
    badaboom [OP] Well-Known Member
    Rick
    GEN1 1998 Toyota Tacoma SR5 4cyl. 2.7
    Pretty much nothing yet rolls drives sucks fuel
    1998 tacoma 4x4 SR5
    Windshield Washer sprayer works for short time and then Nothing.
    Replaced end pigtail that attaches to the pump new, new washer pump
    all symptoms continue
    Check the system unplug the pig tail near washer tank pump then
    the pump and system work for a short period of time like a week or what ever and
    then nothing until i go and message it again.
    Unplug short pigtail to windshield washer spray pump and check over work short period then dead again.
    Any help
    Thanks
  2. Jun 23, 2019 at 6:22 PM
    Wulf
    rock raisin
    Have you checked the fuse? I've been told there's also a relay but haven't found where it is yet.
    I have the opposite problem, the sprayer runs continuously til I unplug the pump at the washer bottle
  3. Jun 23, 2019 at 6:33 PM
    badaboom
    Rick
    Which fuse and location ? Because the fuse i have checked is for the windshield wipers and that's not the issue.
    under hood or interior cab for fuse location ?
    I replaced the very end short pigtail near the washer pump because i felt there was an internal relay that
    may have been faulty. Thoughts?
  4. Jun 24, 2019 at 1:03 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What brand pump ??
    Have you checked the voltage at the pump??
    Sounds like you have a poor connection how did you make your splices ?
    Might be a broken wire that opens at random
    Since it works when you move things around again gotta be a connection or a broken wire that opens at random
  5. Jun 24, 2019 at 4:35 AM
    badaboom
    Rick
    trico pump new, last pigtail new toyota part connects harness to pump final leg.
    replaced and cleared out nozzles hoses tending to agree allot of analysis and tracing i guess
  6. Jun 24, 2019 at 6:08 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    When the pump quits, disconnect it and throw your leads from your DMM in there and make sure it's getting 12VDC. If you have voltage but not spraying, pump is failing. If you're dropping voltage and that's why pump is quitting, time to check wiring, etc. Is there a relay for the windshield fluid sprayer motor?
    Wsidr1 and Wyoming09 like this.
  7. Jun 25, 2019 at 1:08 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    My 2000 EWD shows no relay
    I say since it works after shaking and wiggling the wires it has to be near the pump
    cruiserguy likes this.
