Windshield Washer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by My4x4Tacoma, Apr 28, 2012.
  1. Apr 28, 2012 at 4:14 PM
    My4x4Tacoma
    My4x4Tacoma [OP] Member
    2012 Reg Cab, 4x4, I4
    Still getting to know my new 2012 Tacoma.
    Noticed today that when the windshield wiper lever is pulled back for washer that the fluid is sprayed onto the windhield but the wipers dont turn on. Then have to turn on the wiper in a separate operation.
    Is this the correct operation of the washer for the Tacoma, or have I found a problem already ?
    Thanks
  2. Apr 28, 2012 at 4:16 PM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    sprayers should spray, then a second later the wipers will start. something is wrong then.
  3. Apr 28, 2012 at 4:25 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Looks like a defect, unless the base model with non-intermittent wiper stalks behave differently (assuming that's what you have).
    Do your wipers do single wipes when you move the stalk up?
  4. Apr 28, 2012 at 5:45 PM
    My4x4Tacoma
  5. Apr 28, 2012 at 9:07 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    That is normal operation for a base model without intermittant wipers. Upgrading the wiper switch stalk to the intermittant one is easy and will give intermittant wipers and the wipers will come on automatically when washing. Cost is roughly $100 with new parts, search here, you'll find a DIY.
  6. Apr 29, 2012 at 2:19 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    pull lever back all the way for at least two seconds...see how that works
  7. Apr 29, 2012 at 5:00 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The wash system doesn't work as well as other vehicles I've driven. I always switch it to fast to clear the windshield or else it wipes once or twice.
  8. Apr 29, 2012 at 6:56 AM
    StickShifty
    New Jersey
    2012 AC 4WD 6SPD
    wow talk about skimping out on the base to save money. you would think they would put in this feature
  9. Apr 29, 2012 at 7:07 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    they need to fix this,its 2012
  10. Apr 29, 2012 at 7:22 AM
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    that will be my next change, real wipers and cruise control.
  11. Apr 29, 2012 at 8:47 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Here's how it works on a base model: the windshield will be completely covered in washer fluid after two seconds, but the wipers will not come on until you switch them on.
