Windshield washers won't spray?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by snowman555, Feb 16, 2019.
  1. Dec 8, 2021 at 4:29 AM
    #41
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Orange rain x in my tank, first cold-ish morning and it sprayed for a couple seconds then drivers side quit, then passenger quit. ....well, shit.
    I don't suppose there is a drain on the tank. Can the delivery hose be used to drain the tank assuming the clog is in the nozzle or does the pump prevent flow?
  2. Dec 8, 2021 at 7:02 PM
    #42
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Worst case buy a transfer pump at Ocean State Job Lot or Harbor Freight.
  3. Nov 14, 2022 at 9:20 PM
    #43
    cak
    cak Well-Known Member
    Palo Alto, CA
    2017 V6 4x4 SR5 ACLB
    Seems like ... a real design flaw that this system can possibly freeze up, given the proximity to the engine heat. I use -30 fluid and still have problems with it icing up in anything below 25.
  4. Feb 16, 2024 at 3:25 AM
    #44
    metalmitchp
    metalmitchp New Member
    2018 Toyota Tacoma
    Thanks for this thread. Blown fuse was the problem here. I replaced with the spare stored in the fuse box in the engine compartment. So, zero cost. Except for the gallon of fluid I bought when I thought I was out. :)
    Never had this happen on any non-Toyota vehicle. But if this the worst thing I have to deal with on a Tacoma, I'll take it.
  5. May 18, 2025 at 5:10 PM
    #45
    Johnnny13
    Johnnny13 Member
    Oregon
    2017 White TRD Off Road 4X4 DCLB
    Had the same issue. I pulled the 10 fuse from the fuse panel under the dash. Then I replaced it with the spare 10 fuse from the fuse box under the hood. I'll take the old one to NAPA to get a spare.
