Windshield Wiper Contact
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rkennedypga, May 17, 2025 at 1:29 PM.
  1. May 17, 2025 at 1:29 PM
    Rkennedypga
    Rkennedypga [OP] Member
    ‘01 Tacoma SR5 PreRunner 4x4
    I’ve already replaced the blades and the wiper arms and spring and yet there still a lot of areas where the blade is losing contact with the windshield.
    Where should I look next?
    2001 Tacoma SR5 V6 4x4
  2. May 17, 2025 at 1:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^If the blades are losing contact in areas where the windshield curvature is greater, you can try suffix-B Bosch Icon blades.
  3. May 20, 2025 at 11:43 AM
    Rkennedypga
    It’s actually not at the ends of the wiper blades. on the passenger side it’s 2 spots, 1/3 in from each end.
    on the driver side, it’s 1 spot 1/3 in from the far tip.
  4. May 21, 2025 at 7:36 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I would take one of the blades off the truck, sight down the length of it, and see if there are any ripples in it.
    If you haven't already done so, blow $50 for a set of blades from your friendly Toyota dealer and see if that makes any difference. I used to just replace the rubber parts with a set from a Toyota dealer, but as of 3-4 years ago that dealer stopped stocking them. :(
  5. May 21, 2025 at 7:52 AM
    Rkennedypga
    Already replaced the blades.
  6. May 21, 2025 at 8:52 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I swear by these...but having trouble finding a set...everyone wants to sell one blade at a time
    I bought a set for about $55 4 yrs ago
    'PIAA's Super Silicone Wiper Blades are designed to be the wiper of choice for many vehicles. Its revolutionary silicone insert means cleaner windshields and greater visibility.'
    best you can get....they give you silicone to coat the glass
    Amazon.com: Piaa 97053 Si-Tech Silicone Wiper Blade - 21" 525mm (Pack of 1)" : Automotive
