Windshield wiper fluid reservoir leaking???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by especk, Nov 4, 2011.
  1. Nov 4, 2011 at 7:28 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    I noticed fluid leaking from my truck after I parked it for a few hours (pics attached). Before that, I tried to use my wiper-fluid to clean my windshield this morning but no fluid came out - it was either empty or the line was blocked. I had my oil changed at jiffy-lube first thing this morning and told them no fluid came out - they mentioned nothing about it after that. I'm assuming they topped off the wiper fluid.
    Has anyone had their windshield wiper fluid reservoir leak from the bottom? It may be a crack or it may have just rubbed through. I haven't taken it out to get a better look to see exactly what happened - I will do that tomorrow. My reservoir was about half-full 6 hours after I left jiffy-lube.
    The fluid was coming out from underneath the wheel well from a hole near that orange part in the picture. I know the crappy cell phone pics suck.
    Any ideas?
  2. Nov 4, 2011 at 7:35 PM
    especk
    Erik
    Redding, CA
    major drip
  3. Nov 4, 2011 at 11:56 PM
    especk
    Erik
    Redding, CA
    any help? has this happened to anyone else?
    obviously i'll find the answer when i remove it tomorrow and take a look but i am more curious if anyone has had the same problem. only 35,000 miles on the truck.
  4. Nov 5, 2011 at 4:18 AM
    Tacoma Mike
    Southern Maine
    Sometimes the hose will pop off
    Sometimes a crack in the tank
    sometimes the seal around the pump leaks by
    sometimes the pump itself leaks.
    I've seen it all.
  5. Nov 5, 2011 at 1:15 PM
    especk
    Erik
    Redding, CA
    the hose was cracked near where the tank attaches on.
    pretty easy fix. just take out the two bolts, unplug the wire harness, cut off the 1/2 inch of damaged hose, and then put everything back.
