Windshield Wiper Lever Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by derekabraham, Nov 24, 2011.
  1. Nov 24, 2011 at 10:10 PM
    derekabraham
    derekabraham [OP] Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I did some searching but I couldn't really find anything relevant, so here it goes. It's kind of hard to explain, bear with me. :eek:
    So I've got the intermittent wipers on my 4Runner (shouldn't be too different from the Tacoma's! :eek:), and they work fine. All the different settings work.
    You know how there's three different lever positions?
    1) 1st position-intermittent controls (mist-light rain I guess?)
    2) 2nd position-moderate rain
    3) 3rd position-downpour
    Ok so basically what's happening is that the 1st position doesn't work properly. The second and third positions work just fine. I'll pull the lever down the 1st position and nothing happens unless I apply the slightest bit of pressure upwards on the lever, at which point the blades will start working. However, as soon as I go over a bump or something, or sometimes the tension on the lever caused by gravity, and the wipers will stop and I'll have to apply a little bit of pressure to the lever again. It's almost like the lever is "loose" I guess you could say. It is VERY annoying.
    Hopefully that kind of made sense. I can get a video tomorrow if I need to.
    Any takers? :(
  2. Nov 24, 2011 at 10:21 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Not the wrong section at all! 1st gen Tacomas and 3rd gen T4Rs are pretty much the same vehicle. :p
  3. Nov 24, 2011 at 10:23 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Plus nobody would see it in the other section. :(
  4. Nov 24, 2011 at 10:26 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Whole damned thing is just wrong......the website, vehicle, basically everything.
    TACOMAworld. :D
    Sorry I have nothing to add. Good luck. I'd think pulling it apart is necessary, maybe a lose wire or some sort of contact point. I've never had one apart.
  5. Nov 25, 2011 at 9:38 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    :spy:
    But I hope not, that sounds difficult. :(
  6. Nov 25, 2011 at 7:18 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
  7. Nov 25, 2011 at 7:28 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds to me like the wiper switch is bad. Obviously you have power to the switch since the other settings work and you also have power to the wiper motor since it works on the other speeds as well. Which leaves the selector switch as the problem. Tme to replace the switch. :D
  8. Nov 25, 2011 at 8:47 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Hard/expensive? :eek:
  9. Nov 25, 2011 at 8:50 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Here's the video.
  10. Nov 25, 2011 at 10:25 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    switch is bad or the interment module for the wipers has gone out.
    Did you check the fuses i dont know if the module pulls from other source with out looking at the wiring diagram on it.
  11. Nov 25, 2011 at 10:50 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    That's the thing though, the individual intermittent settings all work just fine. It's just the fact that when I pull the lever to the first position, nothing happens unless I apply a little pressure upwards on the lever. I don't think it's a fuse.
  12. Nov 25, 2011 at 11:02 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Sounds like the switch to me and nothing else. As you stated, when pressure is applied it works. That says switch.
  13. Nov 25, 2011 at 11:13 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    So I just need to replace the lever?
  14. Nov 26, 2011 at 5:16 AM
    wolftree
    Rick
    Ohio
    Yes, just replace the switch. I expect if you do a search here you will find instructions for replacing the switch. I assume they would be around the cost of 2nd generation Tacoma wiper switches ($90-100). Given the age of your truck, I do not think I would get one from a salvage yard if you plan on keeping it for awhile. Be sure you get the variable switch when ordering, there is little difference in the price.
  15. Nov 26, 2011 at 10:11 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    So the dealership is my best bet?
  16. Nov 26, 2011 at 11:26 AM
    hayabusa3303
    florence sc
    95.5 taco 4x4
