Windshield Wiper Nozzle Replacement Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ehl_jay, May 28, 2025.
  1. May 28, 2025 at 10:20 AM
    ehl_jay
    ehl_jay [OP] New Member
    Hi folks,
    My passenger side windshield wiper nozzle seems to be entirely clogged. Whenever I run the wiper fluid release, all I get is liquid on the driver's side. It's not world-ending, but it is rather annoying.
    I've tried the pin method of pushing things around to see if it cleans anything out or unclogs it, but haven't had luck.
    So, I ordered a replacement, and am looking to install. However, I haven't had a ton of luck finding a guide or video that walks me through the process.
    Anyone have a link I can use to get it done myself?
    Thanks in advance!
  2. May 28, 2025 at 10:29 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    well the easiest is to first start with a sewing needle and stick it down the hole and wiggle it around, sometimes that clears it up and gets them working.
    if that does not work pinch the bottom with a pair of pliers after removing the feed hose. pinch the "fins" back against the body push it back though the hood, scrub around the hole with some alcohol and a towel install the reverse.
    my 2nd gen has I think like Honda odyssey nozzles in them, and they spray in a fan shape vs the 2 pointed ones
  3. May 28, 2025 at 10:35 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW..If you have the new one you can look at it and see the release tab.
