Windshield Wipers Won't Turn Off!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tmantstud, Dec 27, 2008.
  1. Dec 27, 2008 at 9:02 AM
    tmantstud
    tmantstud [OP] High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    While driving my windshield wipers have been spontaneously turning on but will not turn off! I've tried contact cleaner but it only helps for a short period of time. Any ideas on what is wrong or how to fix it?
  2. Dec 27, 2008 at 9:03 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds like you may have a bad fuse, or the wiper motor has a short or bad ground in it. im leaning toward the latter.
  3. Dec 27, 2008 at 9:12 AM
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    Haven't you ever heard of intermittent wipers?
    hmmmm, guess that wasn't very helpful.
  4. Dec 27, 2008 at 9:17 AM
    tmantstud
    Kansas City, Kansas
    I'm just worried the switch may be bad and the entire steering column would have to be pulled to fix it. Because my wiper fluid doesn't work at all either.
  5. Dec 27, 2008 at 11:48 AM
    tmantstud
    Kansas City, Kansas
    except for going through and looking for exposed wires what is the best way to search for a short?
  6. Dec 27, 2008 at 2:54 PM
    tmantstud
    Kansas City, Kansas
    Thanks alot:) I am still a newb with my truck and just try and figure out things as I go. I am starting to think that it is a short because the wiper problem started started again after getting a couple of inches of rain last night. I am going to pull up the diagram and try and fix the problem tonight.:)
  7. Dec 27, 2008 at 3:46 PM
    tmantstud
    Kansas City, Kansas
    I checked the wiper motor/washer pump and did not see any obvious breaks in the wire. I pulled apart the wiper motor assembly and checked for any water, but there wasn't any so I sprayed the contacts with contact cleaner and resealed the assembly. If the problem isn't fixed I will check the wire junction between the wiper motor/washer pump to see if there is a split. Wish me luck that I don't have to check for shorts behind the firewall. Thank you very much for your help!
    tmantstud
  8. Dec 28, 2008 at 3:04 PM
    tmantstud
    Kansas City, Kansas
    I am pretty sure the washer pump is just plain dead. It hasn't worked since I got the truck 2 years ago, and is really corroded. I'm just going to replace that pump they aren't very expensive.
  9. Jan 2, 2009 at 4:12 PM
    allred27
    allred27 Member
    Did you find out what the problem is? I'm having the same issue with my wipers turning & staying on.
  10. Jan 2, 2009 at 8:29 PM
    tmantstud
    Kansas City, Kansas
    did they come on right after a heavy rain? my problem came back again after after receiving 3inches of rain in one night. If that is the situation then there is going to be a short somewhere in the electrical lines, look for exposed wires.
    Hope this helps
  11. Jan 3, 2009 at 2:03 PM
    allred27
    allred27 Member
    Yep, it happens every time there's heavy rain. I'll look for a short.
    Thanks
  12. Feb 5, 2010 at 11:33 AM
    tmantstud
    Kansas City, Kansas
    The problem has returned. I have had the switch checked it is just fine. There do not seem to be any splits in the wires or junction in the engine bay. I have checked and securely sealed the grommet leading the wires through the firewall. Before they would come on when when I turned the key to the second position, now they come on and wont turn off only if the truck is started. Do I need to pull off the cowel and check for leaks behind the firewall? If so what is the easiest way to take it off without breaking the plastics clips that hold it down?
  13. Feb 5, 2010 at 11:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check for a bad relay. The contacts may be stuck.
  14. Feb 5, 2010 at 11:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    Scratch that, it appears it is all contained in the switch.
    EB Group likes this.
  15. Feb 5, 2010 at 11:42 AM
    98tacoma27
    Ben
    Not Beech Creek
  16. Feb 5, 2010 at 12:25 PM
    tmantstud
    Kansas City, Kansas
    I just pulled off the cowl and wiper motor to inspect to shorts but I didn't find any. I'm pretty sure the motor should be fine cause under dry conditions everything works the way it should. It only seems to happen when it rains or snows. But ill try the check system.
  17. Feb 5, 2010 at 12:29 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Just break em off :laugh: j/k...
    Check for a bad fuse :)
  18. Feb 5, 2010 at 12:56 PM
    tmantstud
    Kansas City, Kansas
    just changed the fuse. No luck there. hmmm frustrating:frusty:
  19. Feb 5, 2010 at 12:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    I think your switch is bad dude.
  20. Feb 5, 2010 at 1:03 PM
    tmantstud
    Kansas City, Kansas
    I just replaced the switch. what i find odd is that they will work normally through all the speeds while the ignition is turned to it's 2nd position, but as soon as i start the engine the wipers wont respond and stay constantly moving at the 2nd down setting(low) for the switch. I'm getting limited to either the wiper motor is bad or the relay by the washer pump...
