Windshield Wipers?
Discussion in 'Technical Chat' started by bdunna, Mar 10, 2021.
  1. Mar 10, 2021 at 3:07 PM
    bdunna
    bdunna [OP] Well-Known Member
    2005 tundra access cab
    Not sure where to put this, but have a feeling the general forum will just be people telling me what they just bought.
    Serious question: are there any windshield wiper blades better than factory? What's a decent one? I've used many brands and usually only get a year or two. Stock wipers on my new vehicles seem to last 5, but when I replace them it's never the same.
  2. Mar 10, 2021 at 4:57 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Subbed to see what people say. I use the continuous press wipers from a couple brands. Had good luck with Bosch lately.
    I usually replace mine every fall but I do 40k /yr
  3. Mar 10, 2021 at 5:01 PM
    bdunna
    I've used Bosch in the past. I swear they make deals with manufacturers to sell longer lasting blades. Consumer reports says you don't have to spend a lot, but then won't give recommendations and states they no longer rate them. So they rate them, but don't.
    ottrTaco and doublethebass like this.
  4. Mar 10, 2021 at 5:10 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    You can also buy replacement rubber on Amazon. Don’t have to place the entire blade housing. That’s been hit or miss for me.
  5. Mar 10, 2021 at 9:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  6. Mar 10, 2021 at 9:26 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    I thought of the same question when needed to replace my wiper blades the first time... For me, I pretty much just went with whatever list of blades that were the most highly rated with a minimum of 10,000 ratings, and took a random potshot to "add to cart".
    doublethebass likes this.
  7. Mar 10, 2021 at 11:31 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you can get 5 years from factory wiper blades go for it.
    I change my drivers side every 3 months I do the passenger side when the rubber breaks as needed
  8. Mar 11, 2021 at 12:27 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I replace my wipers every year in the fall just before the winter season starts. I buy major brands like Bosch or RainX or others that I generally find on sale. . Just found Rain X brand yesterday cheap at Costco so I bought 2 sets. I’m good for replacement for 2 years now. I don’t see the sense in keeping wipers for years. It certainly doesn’t break the bank to replace them yearly. Wiper manufacturers and the auto industry recommends you change blades every 6 months to one year. If you ever have to drive along ways in stormy conditions you’ll be happy that you replace your wipers at least yearly. It’s a safety thing.
  9. Mar 11, 2021 at 2:21 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
  10. Mar 11, 2021 at 2:50 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I've got a Corolla as well as two Tacos, and have been going thru wiper blades far more often than I once did. If they last a full year it's unusual. And buying them locally has become expensive for blades that don't last. Napa and O'Reilly's sell cheap Anco blades for almost twenty bucks a side.
    So I was looking to buy something on Rock auto and checked out the wipers. The cheap Ancos were less than three bucks, and the Bosch were less than five.
    So I bought blades that will fit on both the Tacos and the Corolla, even if they aren't the recommended sizes. Three sets, two sets already replaced and the third stored until they are needed. Even with shipping they were much cheaper than the local shops. I like to buy local, but I don't like it when they rape you.
    Sprig likes this.
  11. Mar 12, 2021 at 7:50 AM
    bdunna
    That's the thing, even buying from the dealer you get an inferior product. It's like they make ones for new vehicles that will last 3-5 years and then after that they build them to wear out quick. I would gladly pay more for wipers that lasted. My 2016 Tacoma's just wore out. Looks like I will just be replacing them yearly now.
  12. Mar 16, 2021 at 12:32 PM
    4BYTOY
    4BYTOY Well-Known Member
    Colorado Front Range
    2018 TRD Off Road
  13. Mar 16, 2021 at 6:46 PM
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    This ^^^
  14. Mar 16, 2021 at 6:49 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    After trying Bosch Icons back in 2015 I refuse to buy anything else. They are the only ones that last me 4+ years. I’ve had them on 3 vehicles so far.
  15. Mar 16, 2021 at 6:58 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    Bosch is the way to go, however I'm not happy with the ones I have now. They jump and make noise towards the top of the up swing, however they are clearing water without a problem. They are too new to be doing this already. Anyways, I still stand by Bosch.
  16. Mar 16, 2021 at 7:07 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I like Rain-X Quantum. It applies Rain-X and has a spoiler design to stay on your windshield in the wind. Plus, they're silicone so they'll last longer than rubber.
  17. Mar 16, 2021 at 7:07 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Swap mine out each spring; when Costco has them on sale.
    Sprig likes this.
