winter blend fuel = ~3mpg drop??
Discussion in '4 Cylinder' started by ttylerr, Oct 26, 2009.
  1. Oct 26, 2009 at 6:23 PM
    ttylerr
    ttylerr [OP] Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    so, my truck, seemingly out of the blue has dropped about 3 mpg average according to my fuelly which i update religiously. my past 2 fuel ups have dropped to about 16.8!:eek::censored: the only thing that's changed that i can think of is that gas stations are switching over to winter blend fuel. does it really make that huge of a difference? i'm getting worse fuel economy than most 4.0litres...:confused:
  2. Oct 26, 2009 at 7:45 PM
    SSrUs
    SSrUs Member
    Damascus, Oregon USA
    '09 4x4 SR5 Access Cab 2.7L M5
    3" Lift, Nasta Step Bars
    I've changed too many things on my truck lately (wheels, tires, lift, synthetic oil) to be able to see any trends in fuel economy.
    But I had my last rig, a 92 Explorer, for 12 years. I always checked the gas mileage. Every winter, I would see a 10% drop in fuel economy when the winter blends arrived at the pumps. It sucks! :mad:
  3. Oct 26, 2009 at 7:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Winter gasoline, denser air requiring more fuel, yes. 3 mpg sounds right.
  4. Oct 26, 2009 at 7:48 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    I have noticed a drop too. From about 19.3 to 17.8. Thats the only thing I can see making that big a difference. Maybe the cooler air is throwing of our Air/fuel mix with it being denser.
  5. Oct 26, 2009 at 8:11 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    well... this being the first year i've ever tracked my fuel economy... i think i'm in for a long even more depressing winter :(
  6. Oct 27, 2009 at 1:25 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yeah it all has to do with the amount of oxygen in the air at colder temps. gas companies nknow this so they accout by adding a heavier fuel mixture tha can ignite under strained condidtions like in the cold weather.
  7. Oct 27, 2009 at 1:35 PM
    ttylerr
    Tyler
    09 MGM 4Banger 4x4
    geeze beastly what do you do to get that kind of fuel mileage... :eek::crapstorm:
  8. Oct 27, 2009 at 1:41 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    oh, well long story, but i dont fill up all the way any more. i jsut do like 8 bucks here and there so i dont bother with it. i used to get like 28-30 but that was when i filled up when gas was like 2.24 a gallon
  9. Oct 27, 2009 at 6:03 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Another possible factor is that when colder, it takes the vehicle longer to reach operating temparatue thereby possibly increasing fuel consumption.
  10. Oct 30, 2009 at 1:04 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    This may be stating the obvious but be certain that your tire pressures haven't dropped due to cooler temperatures. Also, if you're running traditional, dead dinosaur stuff in the engine, transmission and differential, try using a synthetic.
    I've used AMSOIL products since 1978. The ONLY claim I've ever made regarding MPG and AMSOIL is that a user will see a smaller reduction in MPG during winter. It takes a LONG time for gear lube to warm up in the cold. AMSOIL lubes remain liquid at much lower temperatures than dead dinosaur products.
