Winter blend gas. Mpg taking a hit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Jan 6, 2022.
  1. Jan 6, 2022 at 7:30 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Can’t figure out an alarming drop in mpg as of late. Engine idles smooth, good acceleration, Oem copper core plugs replaced 6 mo. ago. Nothing obvious detected. Was getting good mpg up until 2 weeks ago. But wow! Now almost 5 mpg less! Is it probably winter blend gas? I imagine winter blend gas must hit 1st generations with their aging engines. Heh, it’s gotta be that!
  2. Jan 6, 2022 at 7:35 PM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    I usually take a 2-3 mpg hit with the winter blend. :annoyed:
    Mmaira2018, jowybyo and alarka like this.
  3. Jan 6, 2022 at 7:38 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Winter blend gas will clean out your fuel system and clog filters up, too. It takes more ethanol to make power than gas, so expect a mileage drop.
  4. Jan 6, 2022 at 7:47 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Still a half tank late summer gas in the tank.
    :anonymous:
  5. Jan 7, 2022 at 3:29 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    There are so many different blends across the country some are much worse then others.
    Myself ! do notice in the winter it is not uncommon to idle a extra 30 minutes a day
  6. Jan 7, 2022 at 8:40 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I track my mileage in an app I wrote to manage my finances. I've noticed the MPG hit in the winter for a couple of years now. It goes from about 18 to 16 with the winter blend.
    Tacoma~Gal, alarka and Bivouac like this.
  7. Jan 14, 2022 at 7:55 PM
    Caslon
    It might be the Circle K gas I been getting for a drastic drop in MPG. 4 months ago, that station’s gas got me kick ass MPG. Last few fill ups, crap MPG. Stopped by a Sinclair station and filled up. So far I notice my fuel needle not practically dropping as I drive. 45 miles so far and the needle still at the full mark! Where you buy gas matters, maybe, or…what batch they got, or…? BTW, when Circle K got me kick ass MPG, mainstream big name station gas got me a lot less MPG. Go figure. There’s probably a lot of factors as to why.
  8. Jan 15, 2022 at 3:59 AM
    WorldwideTacoma
    WorldwideTacoma Well-Known Member
    Jay
    2018 Cement Grey TRD 4wd/1999 Tacoma S/C TRD 5 Spd 4wd
    I try to stick to top tier gas stations to eliminate that out of the equation. Circle k’s are not known for their good gas. TBH I will never pump at a circle k.
  9. Jan 15, 2022 at 4:01 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Have you tried the winter blend from Dunkin?
    04taccoo, Bivouac and Mmaira2018 like this.
  10. Jan 15, 2022 at 7:40 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    People really worried about MPG's with these old trucks?
  11. Jan 15, 2022 at 8:06 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    5 mpg drop is significant.
    I'm sure some is due to winter blend. Are you idling on start up to warm up the engine? This will have a BIG impact of fuel usage.
    Snow/ice on the road will also impact fuel usage.
    Probably nothing needs fixing.
  12. Jan 15, 2022 at 8:12 AM
    Caslon
    That’s what stokes me. It’s not my engine. It’s the freaking gas! Smooth idle, no oil loss, fairly recent plug change. I was getting batty about my recent plunge in MPG. A big plunge. Watching the needle drop as I drove. Circle K gas at this one place done me well before. Wha happened? Heh. Also, stations are supposed to show a symbol on the pump that their gas here in So. Calif. is rated as being of a certified quality. Circle K has no such a sticker…for awhile now…used to. I noticed that sticker not on the pumps now. Circle K gas is labeled as CFO gas. WTF is that?Canadian in origin I believe.
  13. Jan 15, 2022 at 8:25 AM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    Same here and more warm up times with the cold temps as well.
  14. Jan 15, 2022 at 8:32 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Yes. The difference each way of 5mpg on a trip out to my parents’ house (330miles) is $25. Not to mention that a truck that one day makes 20mpg and the next makes 15mpg is something worth looking into and/or fixing
  15. Jan 15, 2022 at 8:38 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not that much but I take 2-3 a gallon loss in winter. Regardless of the time of year I don't idle it to warm up the engine so I can say my experience is consistent.
  16. Jan 15, 2022 at 8:43 AM
    Nano909
    Xcab 3.4 4wd 5MT
    5mpg is insignificant. If the vehicle is in the shape OP described, then chalk it down to crappy gas. Simple.
    Maybe sell the truck with crappy gas mileage and buy a hybrid or something. I daily my Tacoma and am probably one of the people that pays the most for gas. If I wanted to save gas then I wouldn't drive the truck, although my Audi on E40 isn't exactly a gas saver either.
    Bivouac likes this.
  17. Jan 15, 2022 at 8:46 AM
    OpeCity
    Long Beach, CA
    5mpg is not insignificant. That’s a 25% increase in consumption. That’s worth at least understanding the source of the change. Could be bad gas, could be broken shit.
    I'm glad you don’t care about fuel mileage, and that you spend more on gasoline than I do, but don’t hassle those of us who care.
    Mmaira2018 likes this.
  18. Jan 15, 2022 at 8:49 AM
    Nano909
    Xcab 3.4 4wd 5MT
    I'm in Socal and I don't see a difference in gas mileage. I'm at ~200mpt year round, it will probably be less now since I just installed steel bumpers. A regear should help.
  19. Jan 15, 2022 at 8:51 AM
    Nano909
    Xcab 3.4 4wd 5MT
    Sometimes you have to remind people that they're driving a terrible mileage truck that's over 20 years old because for some reason they're expecting Prius mpg's.
    Bivouac likes this.
  20. Jan 15, 2022 at 8:53 AM
    OpeCity
    Long Beach, CA
    Nobody is expecting Prius mpgs. Not sure where you got that from. I get 20mpg and am happy with it. if I suddenly got 15, I’d try to figure out why
    Thatbassguy likes this.
