Winter Driving in a TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerbarian, Dec 26, 2015.
  1. Dec 29, 2015 at 11:57 AM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    living in Vernon bc and working up north as a truck driver I can give my suggestions with the included traction control buttons.
    1. I would be in 2wd with no extra buttons pressed. standard 2wd mode is open rear diff and stability assistance so if you do kick out the back end it will apply the brakes appropriately to straighten it back out. if you are slipping a tire it's a sign to slow down and decide if it's 4wd mode.
    2. I would run in 4wd under 50mph in this condition. you can decide to engage the electronic lsd at this point which will allow more throttle control by the pedal and less restriction on the slipping wheels. disengaging the traction control all the way (press and hold till it states off) would be great for attempting hills you need to take runs at off road or maybe driveways filled with snow.
    3. 4hi w/tc off - I would use this for most situations so you don't break you tires free of traction and lack of severe binding in sharper turns (shouldn't be that bad) and use 4lo under crawling or slow moving conditions. make sure to apply the yellow wire mod asap if you do this off-roading more then 4 times a year.
    4. parking binding happens but if your in a parking lot needing 4wd you wouldn't be binding. try 2wd with electronic lsd engaged (traction control button pressed once) and enjoy easy steering.
    tires are a huge part of driving in the winter and I run duratracs year round. in bad weather I go from 38psi in my 275/60r20 p rated tires down to 25-30 depending on conditions. I drive the "highway thru hell" road like its a Sunday drive
    Rusty1606 likes this.
  2. Dec 29, 2015 at 12:27 PM
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    The previous version of the BFG AT's were not known for good mud and snow traction because the treads would load up with mud/snow and not clean out well. However, the recent redesign is said to have greatly improved clean-out, and several online and magazine reviews have confirmed this. I have the previous version (came on my '13 Baja) and have a friend with the newer ones. Big side-to-side differences. That said, I have been running BFG AT's design for decades - on a '78 Bronco, a 2000 Dakota, and now the Tacoma - and never had any complaints. They are a good compromise between street and off-road, and I had no issues with them when I lived in Pittsburgh where the hills are steep and the snow is bad.
  3. Dec 29, 2015 at 12:49 PM
    wedgemoose
    wedgemoose Well-Known Member
    Wedge
    Worcester,MA
    2014 TRD Sport
    Oh Ok. That I don't care about. All as I care about is traction. I was always told you want skinnier tires for snow so I was a little worried about this year with my new BFG's. But I'll tell you, this morning they seemed great. So far so good. But when we get the real stuff will be the big test.
  4. Dec 29, 2015 at 2:51 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    Harder = less traction and faster wear
  5. Dec 29, 2015 at 4:43 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    What are all these traction modes the OP talks about?
  6. Dec 29, 2015 at 5:06 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Hard compounds mean slower wear. Soft compound winter tires wear faster.
    SigSense and SJC3081 like this.
  7. Dec 29, 2015 at 5:07 PM
    StevoNB
    NB, Canada
    See post #6.
  8. Dec 29, 2015 at 5:12 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    My 09 taco is great in the snow. Road tires and no weight. I rarely need 4HI unless up a real steep hill or huge drifts.
  9. Dec 29, 2015 at 5:56 PM
    PackCon
    Connor
    Yeah I went back and started reading that. Have no clue what all that is. Probably will never use them.
    That post really doesn't explain what things are, just that they are there for XYZ conditions. So not very helpful.
  10. Dec 29, 2015 at 6:01 PM
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    yes and no. there is a point where hard tires scuff and wear faster. mostly with year round tread patterns. however wear is truly based on rubber compound. when rubber hardens it wears faster due to excess friction when running down a road. it's basically like doing a small burnout every time you press the throttle.
    another comparison is tread siping actually extends tire life due to this same reason as well as increasing traction.
  11. Dec 29, 2015 at 6:07 PM
    PaulK
    Paul
    Pittsburgh, PA
    My current set of BFG's have 25k on them and are hardly worn. The last time I replaced a set was on my Dakota. They had 50k, plenty of tread left, but were starting to show cracks in the sidewall from drying out. They were probably 6 years old. The truck left us at 130k still on its second set. The original Good Years were shit, and were nearly bald at 30k.
  12. Dec 29, 2015 at 7:42 PM
    Schaffer
    Schaffer Well-Known Member
    PA
    2015 Access Cab
    I haven't had a chance to drive my Tacoma in the snow yet but have driven other 4wd and awd vehicles extensively. I had a 98 ranger and a 97 dakota. Most of the time i was driving in 2wd unless the snow got deep enough, usually 5-6 inches was where i was putting it into 4hi. My ranger had Maxxis Bighorns on it, they did pretty good in the snow with a bit of weight in the back. I had no issues in my dakota, which is still wearing a set of General Grabber AT2 tires. The generals work great on my dakota and my dad has a set on both of his vehicles. The only times i used 4lo in the snow was if i was wheeling or trying to get unstuck.
  13. Dec 29, 2015 at 8:31 PM
    StevoNB
    NB, Canada
    Yea I went back and read it too. I'm not even sure it's even the same on 2012-15's. Basically you press the vsc off button, you get less electronic nannies. Press and hold for 3 seconds, you get less again.
  14. Dec 29, 2015 at 8:47 PM
    Pigpen
    Dan
    Northwest Montana
  15. Dec 30, 2015 at 2:39 AM
    #35
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Ouch!
    Beat you to it ;) (EDIT: could've sworn I threw in the winkey face before!)
    Pigpen[QUOTED] likes this.
  16. Dec 31, 2015 at 5:39 AM
    #36
    Fishless2he
    Fishless2he New Member
    Ottawa Ontario
    2015 TRD Sport
    Great thread with lots of valuable info. I have a question, when switching from 4WD back to 2WD (while brake is applied)is it normal to hear a clicking noise in the back-end. I had a 2001 Dakota for 14 years and when switching from 4WD to 2WD I never heard anything it was a smooth transition, so I'm wondering if this is normal? I've only had my truck for 5 weeks and had to use the 4WD for the first time this week.
    Thanks in advance,
    Sheldon
  17. Jan 3, 2016 at 11:35 PM
    #37
    Beerbarian
    Beerbarian [OP] Member
    2010 Red Tacoma TRD Sport
    Lift kit, rugged tires, beer stickers.
    Thanks, this was really helpful. Also, thanks for the links to the different driving modes that others posted.
    https://www.tacomaworld.com/threads...rols-trac-auto-lsd-a-trac-rear-locker.212057/
    This is really useful info. This is really what I was looking for. I found a few threads that used a lot of abbreviations, etc, and I wasn't sure what they all meant. That's a damn good post.
    Basically, what I am taking away from the replies here, and that post is:
    1.) Get some weight in the back of my truck.
    2.) If I feel like I really need 4H, use it, otherwise, I should be in pretty good shape with 2H.
    3.) If I am really slipping in a deep snow scenario, I should press and hold the VSC button for 3+ seconds to get maximum traction while in 4H.
    4.) 4L is more for POWER, not TRACTION.
    5.) Get more appropriate tires.
    Sound like I got it pretty much figured out? Let me know if I translated anything incorrectly.
    Right now, I have some fat off road style tires on my truck (came with them) and they are not best suited for snow driving. However, I don't have the spare scratch for snow or better all weather tires right now as I just got some new tires for my wife's Nissan Juke. (She's not as experienced as I am in snowy driving conditions, so I did the chivalrous thing. :) )
    Thanks again for the great advice. This is a great forum!
  18. Jan 4, 2016 at 6:49 AM
    #38
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    I think you got it. Basically only thing is 4lo is for low speed control and if you need it power. For example if you have a super slippery hill you can help control your speed down it by going into 4 low and allowing the motor to help more without using the brakes.
    Everything else is great. What tires do you have on the truck now?
  19. Jan 4, 2016 at 8:24 AM
    #39
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    After this mornings icy Tokyo drift across multiple lanes, I can concur with the adding weight in the back will most likely help keep the rear end planted.
    Damn 2006 with no traction control...
    Snow varies here in New England but I have only ever had to use 4H from 1-10". Also applies to beach driving in the summer as well.
  20. Jan 4, 2016 at 1:06 PM
    #40
    Beerbarian
    Here's the tire I have on the truck now.
    http://www.nittotire.com/light-truck-tires/trail-grappler-mud-terrain-light-truck-tire/
