Winter Fluid Recommendation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mdhtacoma, Sep 6, 2020.
  1. Sep 6, 2020 at 2:11 PM
    Mdhtacoma
    Mdhtacoma [OP] Member
    Mcihael
    07 Tacoma
    I have an 07 Tacoma TRD 2wd that I just bought with 249,00 miles. I bought in AZ and brought it out to Wyoming. Does anyone have any recommendations for winterizing the motor. It will be in the sub zeros for many months. I was thinking to put a little heavier oil in it but also looking for suggestions.
    Thanks
  2. Sep 6, 2020 at 2:13 PM
    bunk
    bunk Well-Known Member
    Lighter oil will fair better in the cold, ideally synthetic. Check the coolant with a hydrometer. Install some kind of block heater.
    Mdhtacoma[OP] and Hashc93 like this.
  3. Sep 6, 2020 at 2:20 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome Michael :hattip:
    Maybe some preventative maintenance on the frame. Fluid Film/WoolWax :thumbsup:
  4. Sep 6, 2020 at 2:28 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had to work in Gillette one winter, it was so freaking cold with the wind chill, the antelope would take refuge between the house's. The ole saying in Wyoming is it blows on one end and sucks on the other.
    It’s a beautiful state though, loved Wyoming when I wasn’t working. Get a block heater is my advise, have a new battery, and always have insulated carhartts coveralls in your vehicle in winter, It just may save your life.
    Sprig, winkel and Mdhtacoma[OP] like this.
  5. Sep 6, 2020 at 2:28 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Unless you know when the fluids were last changed I would start a systematic change of all fluids.
  6. Sep 6, 2020 at 2:37 PM
    Hashc93
    Hashc93 Well-Known Member
    I doubt you will need a block heater...
    5W30 will be fine
    Just change out the Anitfreeze to a higher concentration.
    2WD GET A SET OF QUALITY SNOW TIRES
  7. Sep 6, 2020 at 2:39 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    OEM things are fine. Just some rust protection and make sure your coolant isn't just plain water and you're fine (50/50 preferably). No need to change to a different oil or any other fluids. These things are designed to run in all different conditions. You'd only need a block heater if you had a diesel, and even GM's baby Duramax is designed to start in -30°F without a heater.
    I have a co-worker from FL who was told the same stuff about fluids and things when moving up to Michigan. Just regular maintenance and you should be good.
  8. Sep 6, 2020 at 2:59 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    You may not NEED a block heater, but they do help prevent premature wear. A warm engine is easier to turn over than a cold engine and cold oil may or may not flow depending on multiple factors I installed a pan and a block heater on my taco when I worked in North Dakota. Could bring the external temp of the block up to 30 degrees Fahrenheit on a -10 day. Find a piece of cardboard to put in front of your radiator too and keep it handy. Just don’t forget that it’s there when it starts to heat back up.
    Mdhtacoma[OP] and RedWings44 like this.
  9. Sep 6, 2020 at 3:13 PM
    RedWings44
    Michigan
    Yes. I've started many vehicles in -24°F temps and colder without issue, but you definitely want to wait until it has some heat in it before you do anything if possible, or at the very least take it easy. In the old days of carbs, your vehicle just wouldn't start. Modern engines will start, but most wear comes from when the engine is cold. In general, no, you don't need a block heater, but it isn't going to hurt either.
    Mdhtacoma[OP] likes this.
  10. Sep 6, 2020 at 3:18 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd flush the coolant and have it tested.
    The rest is all fine, just run 5W30 or if its stupid cold 0W20. WY doesn't look thaaaaaat cold. Just run 5W30 as the manual states.
  11. Sep 6, 2020 at 3:19 PM
    Hashc93
    Where in Wyoming? It’s a big ass state that varies quite a bit
  12. Sep 6, 2020 at 4:22 PM
    Mdhtacoma
    Mcihael
    07 Tacoma
    Definitely did that already with predrilled holes for the spikes
  13. Sep 6, 2020 at 4:24 PM
    Mdhtacoma
    Mcihael
    07 Tacoma
    Star Valley area south of Jackson Hole.
    Hashc93[QUOTED] likes this.
  14. Sep 6, 2020 at 4:28 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    This for washer fluid.
    igno1tus and Mdhtacoma[OP] like this.
  15. Sep 6, 2020 at 4:29 PM
    Mdhtacoma
    Mcihael
    07 Tacoma
    Thank you all. I plan on doing the oil change to synthetic this week and will stick with the 5/30. Also will take the suggestion of flushing radiator and 50/50 refill. Loving my Taco I havnt had a Toyota since the 90s I built an 84' SR5. Glad to be back in the saddle. Cant wait to have my boy Brian at Lil Bs, in Colorado hook me up with a new Bumper/skid plate. Next spring will be fun.
  16. Sep 6, 2020 at 4:33 PM
    Mdhtacoma
    Mcihael
    07 Tacoma
    I do have a little valve tap and the P2014 code about the cam solenoid so I am looking into that as well. Otherwise this truck runs great already put over 3k miles on it in the 6 weeks I have had it. Got chased out of Yellowstone yesterday by a fire near old faithful. Sat in 6 hours of traffic on a 45 mile stretch no overheating with A/C on. No oil leaks incredible for the miles on it. Cant say as much for my Harley ;)
  17. Sep 6, 2020 at 4:35 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Heated Seats, maybe heated steering wheel
    Might not need block and battery heaters, but they are nice safety measures to have
  18. Sep 6, 2020 at 5:38 PM
    ToyotaDriver
    Idaho
    Considering that the majority of engine wear occurs on startup, why would you not plug your vehicle in?
  19. Sep 6, 2020 at 5:54 PM
    RedWings44
    Michigan
    Not having access, setup, cost vs benefit, etc. Like I said, it wouldn't hurt; but, it won't make a big enough difference in my opinion if you don't have something like a big diesel that just plain won't fire. The primary purpose of a block heater is to ensure the oil flows easier.
  20. Sep 6, 2020 at 6:58 PM
    ToyotaDriver
    Idaho
    https://www.etrailer.com/Vehicle-Heaters/Kats-Heaters/KH11481.html?feed=npn&gclid=CjwKCAjwkdL6BRAREiwA-kiczFXbYpCk2EblE1gpGl9wVQ73yEV250vgwWGkI93D_VtxqmERD6mnQRoC5aMQAvD_BwE
    Literally took a screwdriver a hammer and 45 min to install including filling the fluid back up. Also costs less than your wal mart seat covers. Oil not flowing on startup isn’t exactly a cheap issue. How expensive? Depends on how long you keep your vehicle and the conditions it’s subjected to, but for sub $50 including the fluid to refill, it’s a cheap insurance policy. Also, fun fact, at -64, a tacoma with a block heater barely wants to start.
