Winter Gas Blend?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by krap22, Feb 22, 2012.
  1. Feb 22, 2012 at 2:56 PM
    krap22
    krap22 [OP] Well-Known Member
    I've never heard the term used with Gasoline until i found TW. I think is a bunch of crap personally. I've had tanks near 20 mpg this winter and tanks near 16 mpg. When its warmer (over 40) is when i get closer to 20. When it is in the 20's and lower is when i get closer to 16.
    I don't see how i could get nearly 20 mpg if the gasoline was what was causing the issues. Does anyone have any links to prove that there is a winder gas blend for gasoline or is this just a big urban myth.
    My personal thoughts are that the air is much more dense when it is colder causing more air resistance. Also fuel doesn't' atomize as well at lower temps causing more fuel to be dumped in.
    Maybe I'm wrong, but the winter blend doesn't make sense to me. Can someone point me to some real proof that a winter blend exists?
    :bananadead:
  2. Feb 22, 2012 at 2:59 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Feb 22, 2012 at 3:01 PM
    OZ-T
    Peter North
    British Columbia
    Try Google and why is this in 2nd Gen
    and Niburu
  4. Feb 22, 2012 at 3:08 PM
    krap22
    Thanks Oz.
    it goes in 2nd gen cause it will get the most attention there. Duh!
  5. Feb 22, 2012 at 4:46 PM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Not only a winter gas blend but there is also regonal gas blends for different parts of the country.I saw on the news this past week that there is over 30 different blends depending on where you live.All these special blends help drive up costs.We should only have two blends.Winter and Summer.
  6. Feb 22, 2012 at 7:39 PM
    grhopper
    grhopper Well-Known Member
    Louisiana
    2012 DCLB TRD Sport
    In Louisiana the "summer blend" costs more. There is a certain date range that they must sell the summer blend. I've never paid too much attention to the date and how my gas mileage changes.
  7. Feb 22, 2012 at 9:04 PM
    krap22
    even with the winter blend, i still see more of a correlation to my bad gas mileage with temperature than i do with the winter blend. If the article that Oz linked to is true, then we are using winter blend from middle of sept. through May. I didn't notice a change in my gas mileage until late November when it got cold. :notsure: it just doesn't seem that the winter blend has as much of an effect as people think it does.
  8. Feb 22, 2012 at 9:40 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Colder air is more dense. Thus harder for your truck to push through.
  9. Feb 23, 2012 at 7:40 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Definitely do some searches. Whether you have no winter blend, just a winter blend in winter, or full year winter blend depends on where you life.
    Just consider that it could be worse though, I live just outside of Houston and we get "winter blend" all year round. Most major metro areas get full year oxygenated fuel.
  10. Feb 23, 2012 at 7:44 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Same here. Its that Ethanol in gasoline. Temperature changes its viscosity so it burns like crap. :rolleyes:
