Winter is coming… Driving 4x4 in the snow
Discussion in 'Canada' started by MTB_Tacoma, Nov 9, 2022.
  1. Nov 9, 2022 at 7:11 PM
    MTB_Tacoma
    MTB_Tacoma [OP] Well-Known Member
    2022 Electric Lime Tacoma TRD Pro MT
    Hi all, got AWD vehicules before, but never had a 4x4. AWD is simple, it’s working by itself. All you need to do is turn off VSC when wheels are spinning trying to get out of a slippery situation.
    I kinda understand 4hi would be used in situations when driving in a lot of snow on the ground (in or right after a snowstorm) and I should switch back to 2WD when I hit dry road. 4lo would really be the exception if I get stuck and nothing else works.
    But what about all the other functions? There’s a nice thread explaining what they are, not really when to use them… In regular daily driving situations (worse would be reaching a snowy uphill trailhead to go fatbiking), when do you use the VSC, A-TRAC and locker buttons, if that makes sense?
    Reading the manual, my guess would be if I get stuck and wheels are spinning, push the VSC button to engage Auto LSD in 2WD and see if it helps. If not, push it 3 seconds to deactivate the aids and try again. If not, try 4hi. Rinse and repeat with the VSC button. If all fails, 4lo, A-TRAC and finally locker. Really, in daily driving situations, I’m sure you only have to use 4hi from time to time and maybe the VSC button occasionally.
    I know I’ll have opportunities to try soon, just wondering if I got it right.
    I have a manual transmission, no MTS for me.
  2. Nov 9, 2022 at 7:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Basically thats all you need, switch 2WD and 4WD as needed.
    If you get stuck, experiment, the locker can actually cause you to sink more into the snow, a trac is more ideal sometimes. MTS is a gimmick, a trac and locker are simple and more usable.
    MTB_Tacoma[OP] and Tacospike like this.
  3. Nov 9, 2022 at 7:18 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
