Winter is coming!!
Discussion in '4 Cylinder' started by Maineiack, Aug 29, 2013.
  1. Sep 4, 2013 at 1:19 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    I thought that he was referencing GoT too hahaha
  2. Sep 4, 2013 at 2:15 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 4cyl MT 4x4 Utility Package
    :rofl:
  3. Sep 5, 2013 at 3:43 AM
    dcdlexmass
    dcdlexmass Active Member
    Boston Ma.
    2015 Tacoma TRD Off-Road Double Cab 4x4
    Best to find used if at all possible.
    New ones run well into the mid $4k range ... If you're lucky your may find a local used one for around $2k give or take.
    You may have better luck locating a used Fisher light duty Homesteader or SnowDogg for your 2nd generation truck.
    Although I would ten to stay away from the Homesteader if you're going to be pushing/back-dragging some real snow.
  4. Sep 7, 2013 at 6:29 PM
    work toy
    work toy Member
    darren
    nh
    08 silver rg cab sr5
    air bags, racks
    theres a snowdogg on craigslist off a second gen in littleton mass think it was 2000 or so
  5. Sep 17, 2013 at 6:30 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    I plow and remove snow semi commercially with a Snow Bear type plow. Works great, no problems. I use the truck for tight private drives, narrow areas, and other complex situations. Pushes snow 2 feet+ no problem. Back drags OK in snow 8" or less. So I usually keep up with the snow as it falls so I can backdrag no problem.
    I have stock springs and I do not use any counter weight in the back. Works fine.
    This year I will be upgrading to a Meyer Drive-Pro 7' because I want the power angle. It weighs 100 lbs more than the Snow Bear, so I'll report back if there are any problems. Hopefully it snows like crazy this year.
    My snow killing fleet:
  6. Sep 18, 2013 at 8:00 PM
    work toy
    work toy Member
    darren
    nh
    air bags, racks
    Nice i got the same snow bear. Is yours twin pin mount or front receiver hitch?
  7. Sep 19, 2013 at 8:54 AM
    mrbadwrench
    Cleveland Ohio area
    Twin pin mount, which I guess is the older style. It seems now they switched to the receiver hitch system, which I don't like because it's not as sturdy (Plow wiggles around more) and the receiver hitch hangs down lower in the front than the twin pin system does.
  8. Sep 21, 2013 at 7:19 PM
    Maineiack
    Maineiack [OP] Well-Known Member
    Maine
    2013 stock reg cab 4x4
    Think my mind is made up.
