Winter MPG ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Dec 17, 2009.
  1. Dec 17, 2009 at 6:06 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I've noticed on the Scangauge2 that my MPG has gone way down in the last week or so. It just started to get cold here in NJ. Does that effect it ? Do they put more of that useless corn gas in the fuel this time of year or should I be looking for something else ? :confused:
  2. Dec 17, 2009 at 6:43 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Anti-freeze as well. All the above don't help.
  3. Dec 17, 2009 at 6:48 PM
    jandrews
    '09 FourDubDee TRD OR
    Did you air up for winter? If not, your low tire pressure it probably a significant culprit.
    Also, remember, your fluids are colder, so there's probably gonna be some added resistance in the trans/diffs/engine (until operating temp), some added sapping of power by stuff powered by the serp. belt, etc.
    Cold air is more dense, so you get more aerodynamic drag.
    There are a bajillion factors, but the bottom line is mileage always drops in cold weather. I'd be more worried about road salt...be sure to wash the underbody!
  4. Dec 17, 2009 at 7:22 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    My scan gauge indicated about a 2 mpg drop , down from 23.4 mpg. Also from NJ. Oh, 4 cylinder.
  5. Dec 17, 2009 at 10:33 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    Cold weather definitely has a negative impact on MPG. In the summer, I was generally getting between 19-20 MPG in mixed driving. When fall hit, it dropped to around 17. Now that we've been getting into colder winter temps it's dropped another 1-2 MPG. My last tank yielded 13.3 MPG but that was also with temps of -30 to -40 C. That's probably about as bad as it could get unless I was also using 4x4 extensively at those same temps.
    Funny thing is, my old F-150 with the V8 generally got that same 13-14 MPG in ideal circumstances in mixed driving. In the really cold stuff, it would easily drop to single digits.
  6. Dec 18, 2009 at 1:09 AM
    george3
    New Jersey
    Thanks guys ! Glad 2 C I'm not nutz, well at least as far as winter MPG is concerned. :rolleyes:
  7. Dec 18, 2009 at 2:16 AM
    kevin1970
    kevin1970 Member
    Kevin
    Oregon
    06 4x4 access Cab
    I definatly get worse MPG when it is cold.
  8. Dec 18, 2009 at 3:49 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    me too
    towing in winter :(
  9. Dec 18, 2009 at 4:03 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I do too........and the 4 banger idles faster for a longer period when the temps are low (11 deg F this morning)
  10. Dec 18, 2009 at 4:15 AM
    MGH-PA
    MGH-PA Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Yep, a pretty bad drop here as well. Around 2mpg with cold weather and 10% ethanol.
  11. Dec 18, 2009 at 4:51 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    me to,its the winter additives they put in the fuel as well as all the other stuff mentioned.
  12. Dec 18, 2009 at 5:37 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Horrible, just horrible MPG!
  13. Dec 18, 2009 at 5:43 AM
    george3
    New Jersey
    I didn't think this post would go anywhere but pretty good response. Looks like we are all in the same boat or truck on this one.:(
  14. Dec 18, 2009 at 5:49 AM
    paulm09tacoma
    paulm09tacoma Well-Known Member
    paul
    connecticut
    09 access cab trd
    yup. im losing about 1.5 mpg in the late fall. i think its the mix of the fuel at the pump. also i let my truck warm up a little longer in the cold. i think its just the way it is. 6 cyl
  15. Dec 25, 2009 at 7:52 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Same boat here. Mine has dropped much more than it has in previous winters though. All within a tank or two of gas, I added air to the tires (and rotated), put in a new air filter, changed the oil to synthetic, and replaced the spark plugs. I'm hoping that will help a little bit. I was at 42K and still on the original plugs. They were opened up some, especially the NGKs.
    I keep close track of my mileage to help keep an eye out for indications of issues. This shows my steady decline since summer fairly well...
  16. Dec 25, 2009 at 8:15 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Haahaha.. I check my mileage every tank! its funny to see there is someone worse out there that is keeping a journal! i like it. I a good friend who did this with his Toyota. Its all in excel too! you are above and beyond good sir!
  17. Dec 25, 2009 at 8:21 PM
    PA452
    Western PA
    Thanks. :D
    My original intent was to keep it all on there. But I used to be in the Army and got stationed in Korea. I kept my Tacoma at my parent's house while I was gone, they took it out every now and then just to keep it running, and never kept track of it. So, I have about a 16 month gap.
    I keep all my maintenance events in the same file on another sheet.
  18. Jan 16, 2010 at 9:14 AM
    Snyperx
    Snyperx Seniore Marcos
    My MPG is horrible also. In warm weather I usually get about 17.4 mpg and now with Winter going full tilt here in Wisconsin I am getting about 15 mpg. Sad thing is I have a 15 mile commute on highway and still only get about 15 mpg, maybe 16 mpg. I also recently drove back to see family which was a 160 mile trip and I never broke 20 mpg on the interstate. I have to admit with the mpg being this bad I have considered giving up my Tacoma and getting a Corolla or Civic or something. I can't keep shelling out $60 a week on gas. I don't even have a lead foot, I try not to cause the engine to go over 2k rpm when accelerating.
  19. Jan 16, 2010 at 12:07 PM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    When you cold start your truck, your air/fuel ratio is like 2parts air to 1 part fuel (2:1). Ideally when it's warm it runs at 14.7:1. BIG difference! So yeah, everytime you cold start the ECU is pouring a ton of fuel into the engine to get it started and warmed.
    Other factors such as tire pressure (should be checked everyone month because 3psi=1mpg loss), oil is thicker, etc..
    Also, in the cold more air is forced into the engine because it's more dense. Because of this, your engine needs more fuel in order to keep it's ideal mixture (14.7 to 1)
  20. Jan 16, 2010 at 2:51 PM
    flatlander
    flatlander Well-Known Member
    09 DC-LB 2WD Prerunner V6 Auto
    Same here. Ya'll ought to look into fuelly.com. You get bar graphs, line graphs, ability to export to csv so you can import into Excel. Pretty cool.
    My gas mileage has also been on a gradual decline for the last couple of months.
