Winter Oil Recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a.s., Nov 10, 2016.
  1. Nov 10, 2016 at 2:40 AM
    a.s.
    a.s. [OP] Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    Temps are dropping below freezing and I have an oil change coming up. What weight should I use? Any other "winterizing" tips? Much appreciated. :thumbsup:
    I Know I can do a search for this but I'm bored and I'd like to hear what y'all think.
  2. Nov 10, 2016 at 2:44 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Personnally I keep going with 5-w20 and everything is fine :p
    Jere and a.s.[OP] like this.
  3. Nov 10, 2016 at 2:50 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    use what the manual suggests for the overall temps you will be having.
    Arailt, Large, Sig45 and 1 other person like this.
  4. Nov 10, 2016 at 3:04 AM
    a.s.
    Stack
    NY
    Thanks that was so helpful! :rolleyes:
    10trdtaco likes this.
  5. Nov 10, 2016 at 3:20 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    :goingcrazy::bananadead:
    :rasta:
    jpereira2 likes this.
  6. Nov 10, 2016 at 3:25 AM
    MonkeyWrench462
    MonkeyWrench462 Well-Known Member
    Christopher
    Minnesota
    2013 Tacoma TRD
    K&N Air Filter, Supreme Suspension 3" Lift, Daughters First Pair of vans from Mirror
  7. Nov 10, 2016 at 3:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    The wt oil to use is on the oil fill cap.
    When you look in your owners manual, it will show the temp ranges that wt is good for. If your anticipated temps are outside of that range (doubtful), there will be another wt listed.
    I'd be more concerned my cooling system was up to snuff than an oil wt tweak. I mean you're not going to change all your other lubricant's because of cold are you?
    As far as other winterizing, your tires loose 1 psi for each 10 drop, so keep them properly inflated. Wiper blades and washer fluid may need attention.
    Depending on exactly where you are, a 48 hr survival kit might be a good idea.
    Norton, 1Shifter and a.s.[OP] like this.
  8. Nov 10, 2016 at 3:48 AM
    ChemDawg
    Maine
    2005 sr5 4x4
  9. Nov 10, 2016 at 4:03 AM
    Clearwater Bill
    Billy
    Largo Florida
  10. Nov 10, 2016 at 4:42 AM
    a.s.
    Stack
    NY
  11. Nov 10, 2016 at 4:49 AM
    Large
    Large Red
    best advice you could get and you are sarcastic about it, fuck off
  12. Nov 10, 2016 at 4:56 AM
    a.s.
    Stack
    NY
    Let's see... I'm on a forum, looking to start some banter. I ask a question and specifically say that I know I can look the answer up (whether online or in my manual) but I want some different opinions, insights ...anything really. Then someone gives me the old "look it up in your manual" answer. It's boring but I should fuck off?
    deep breath ... ah okay. I'm just looking for a little fun and entertainment in the morning of discontent. :amen:
    MonkeyWrench462 likes this.
  13. Nov 10, 2016 at 5:17 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If you know the answer, the question and thread are much more useless than you think my answer was.
    Large likes this.
  14. Nov 10, 2016 at 5:18 AM
    ChemDawg
    Maine
    2005 sr5 4x4
  15. Nov 10, 2016 at 5:18 AM
    ChemDawg
    Maine
    2005 sr5 4x4
    Google loves you all.
  16. Nov 10, 2016 at 5:19 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  17. Nov 10, 2016 at 5:43 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Your "panties in a wad" detector must have gone off.... :D
  18. Nov 10, 2016 at 5:57 AM
    a.s.
    Stack
    NY
    Only 4 posts for this thread to go off the rails. That's a respectable number. :D
    Okay so lets recap. Things I should do to winterize my truck:
    1. Read your manual
    2. Make sure your wiper blades are in good shape
    3. Check wiper fluid levels, use winter formula
    4. Check tire PSI as the drop in temps will change tire pressure
    5. Keep a winter survival kit (Unless you live in Florida then you'll need a summer survival kit;))
    6. Fuck off
    Got it. Thanks :thumbsup:
    cosmicfires and 06trdtaco like this.
  19. Nov 10, 2016 at 5:58 AM
    a.s.
    Stack
    NY
    Oh I almost missed one...
    7. Pull panties out of ass crack. :cheers:
    06trdtaco likes this.
  20. Nov 10, 2016 at 6:01 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Glad you caught that. Though I was going to have to call you out again. ;)
    a.s.[QUOTED][OP] likes this.
