Winter Prep
Discussion in '3rd Gen. Tacomas (2016-2023)' started by j_t99, Aug 12, 2025 at 7:14 AM.
  1. Aug 12, 2025 at 7:14 AM
    j_t99
    j_t99 [OP] Member
    California
    2023 Tacoma Off-Road
    Hello!
    I've just moved to the northeast, and I'm wondering if there's anything I need to do to protect my car from the elements. Also, if there's anything that would help it perform better in the snow, for when I want to drive to the mountains?
    For reference, I have a Gen 3, 2WD off-road.
  2. Aug 12, 2025 at 7:20 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Way back in my Navy days, I was stationed in (very) upstate NY and had one of those dipstick heaters for the really cold nights. Other than that, I made sure my coolant strength was up to the task. I am sure some of our resident cold state people will chime in with more modern suggestions, but the above worked just fine for me.
    PS: sometimes I would bring my battery inside for the real bite-ass cold nights.
  3. Aug 12, 2025 at 7:25 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    You might also want to post your questions in the Northeast section. Welcome to TW.
    https://www.tacomaworld.com/forums/north-east.38/
  4. Aug 12, 2025 at 7:27 AM
    Mont Blanc
    Mont Blanc Well-Known Member
    Ron
    01890
    2023 Black Tacoma SR5
    Winter tires. I am a believer.
    Chew likes this.
  5. Aug 12, 2025 at 7:34 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Corrosion protection via petroleum or lanolin based product, on everything metal but, the brakes, BEFORE THE FIRST SNOW/ICE/SALT EVENT. If you dont, you will be sorry next summer. You were warned. :) Ski
  6. Aug 12, 2025 at 11:42 AM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    Definately spray the underneath with corrosion protection !!
    Winter tires. Lots of people like Bridgestone Blizzak. Sipes mean more than aggressive tread, usually.
    A couple hundred pounds of sandbags in the bed. Best if they are over the axle.
  7. Aug 12, 2025 at 11:49 AM
    fmb
    fmb Been here a while
    Ontario, Canada
    2020 TRD OR AC
  8. Aug 12, 2025 at 12:36 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Remember 2wd. Don’t think off road means anything if it’s not 4wd so be careful. Undercoating and washes are important. Check antifreeze, also remember windshield washer fluid needs to be rated for low temperatures
  9. Aug 12, 2025 at 1:30 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    best tires for winter= studded winter tires.
    Then in order:
    winter tires
    all weather tires, note, not all season
    Also consider a plug in block heater if parking outside
    Check antifreeze.
    It should be good to be at least -40.
    An auto parts shop can check it for you with an hydrometer.
    Or you can buy one.
    Buy antifreeze pre-mixed or mix your own.
    50% full strength, 50% distilled water.
  10. Aug 12, 2025 at 1:47 PM
    Buck Henry
    The canuck guy has spoken! Take this to the bank. :)
  11. Aug 12, 2025 at 2:06 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    "Northeast" spans a lot of different climates. Would help if you were more specific. Northern Maine will warrant different strategies than Long Island.
    I spent my first three decades in central New York State (Finger Lakes region) before I moved my cold azz to GA.
    Nobody had block heaters and all was good. Let the motor warm a bit before putting a load on it but otherwise no issue.
    Yes to winter tires. Studs maybe if in icy areas or where they don't plow much, otherwise I never knew anyone with them.
    Definitely do underbody protection - road salt ruins vehicles - clean things up and apply new undercoating each fall.
  12. Aug 12, 2025 at 2:21 PM
    canuck guy
    Alberta
    23TRDOR
    If you read op it says driving in snow and mountains.
    My recommendations were for that as we get a lot of snow, live near Rocky Mountains so a lot of people drive there and temps can be -20 to -30 for extended periods.
    Those are extreme conditions that are common here and of course people have to base their own needs on their own environment. "common sense".
  13. Aug 12, 2025 at 2:24 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Welcome to the opposite of California! (Except for the high prices.) Where did you 'move to' and what mountains would you be driving to?
    As for the truck, get the underside sprayed - oil or lanolin based. Then spray it again.
    Get some good snow tires. Better snow tires. The best snow tires you can reasonably afford.
    Consider what you might need to get un-stuck in the mountains. (tire chains, show shovel, sand, traction aid, etc.) Ask the locals.
    Hard-top bed cover or bed cap/topper, if you're planning to carry any gear in the bed.
    Consider what you might need if you can't get un-stuck in the mountains...
    If you've never driven much in the snow, get out every chance you can and practice driving in the snow. Find a parking lot and see what the truck can and can't do. Better to learn in 2" of snow at the mall, than in 8" of snow on a curvy mountain road.
  14. Aug 12, 2025 at 2:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Upon the first snow storm, drive the truck to an empty parking lot and practice losing and regaining control. Don’t forget to have fun.
    FYI: 2wd pickup trucks suck in the snow. As mentioned above, good tires, and weight in the bed are your friends.
    AK Dudeman and musicisevil like this.
  15. Aug 12, 2025 at 2:50 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    QUALITY STUDDED WINTER TIRES!!!!
    Also it doesn't hurt to add around 200lbs of weight over the rear axle. Consider it a excuse to get a new topper! Or just grab some bags of sand.
    (Bridgestone Blizzaks, Nokian Hakkapelleta, Cooper Snow Claws or Toyo GSI6 get my vote for winter tires)
  16. Aug 12, 2025 at 2:56 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Being 2wd, you will definitely require winter tires. You're rear end will constantly slide out from you. Some people say to put weight in the back. Myself I dont use either as I shove it in 4hi, and I'm gone. But to be fair my tires have the 3 peak snow designation. Not quite a winter tire, but more than adequate for my needs.
    My #1 recommendation is yearly rustproofing!!!!!!!
  17. Aug 12, 2025 at 2:58 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    And to be clear, use a liquid product, not a hard rubber undercoating. Woolwax or Krown is a good option.
    Jakerou and Tocamo[QUOTED] like this.
  18. Aug 12, 2025 at 3:00 PM
    gpb
    Atlanta
    Rockies aren’t really like the Adirondacks or other northern Appalachian mountains.
    For occasional mountain driving people would put on chains, and depending on specific location they might use studded tires, but it wasn’t that common where I lived. Without more specifics from OP it’s difficult to give true advice.
    I applaud your interest in helping OP, and it’s great to share your experience/advice in your area, but maybe don’t correct people who’ve lived through winters where you haven’t.
  19. Aug 12, 2025 at 3:03 PM
    gpb
    Atlanta
    Just watch out for those pesky light poles. :D
  20. Aug 12, 2025 at 7:37 PM
    canuck guy
    Alberta
    23TRDOR
    Well it starts snowing in late October here until May and often (like last year) Alberta and Saskatchewan had snow on the ground and roads for every day.
    So ya I think we know and experience more than the occasional snow driving conditions.
    Most use winter tires.
    Chains are for tractor trailers and were really only used in cars here in the 1960's and '70's
    Not tryin for a pissin match but the Canadian Prairies are nicknamed the "Great White North" for a reason !
    OP asked for snow and mountain driving experience so that's what I gave him.
    That's also from being a ski patroller for 8 years.
