Winter time tire pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pcledrew, Oct 25, 2010.
  1. Oct 25, 2010 at 7:49 AM
    pcledrew
    pcledrew [OP] Well-Known Member
    BC
    '17 TRD Sport DCLB
    Hi to anyone who drives in real winters,
    What's psi should i run in my bfg at tires during winter? This is my first truck and first rear wheel drive (it is 4x4 but I'm talking everyday crappy road driving). Thanks.
  2. Oct 25, 2010 at 8:01 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I think you'll get mixed reviews on this. My opinion, if roads are plowed, don't change a thing and use 4x4 when needed. If roads are consistantly not plowed, drop a couple psi from normal, nothing major, just enough to help fatten the tires out a little bit and give a little extra floatation. Regardless, I'd throw some weight in the bed to help out with traction.
  3. Oct 25, 2010 at 8:03 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I wouldnt have figured you needed to change the PSI?:cool::popcorn:
  4. Oct 25, 2010 at 8:19 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I live in Calgary, and I air down to 29 psi, and it makes a real difference. I usually run 32-34 psi in the summer months.
  5. Oct 25, 2010 at 8:24 AM
    Pugga
    Massachusetts
    So basically don't air down and all, and when it gets to like -100 up there in the Arctic your tires will shrivel down to the correct PSI.:p
  6. Oct 25, 2010 at 8:54 AM
    pcledrew
    BC
    '17 TRD Sport DCLB
    Thanks guys, answers my "?". I did air down to 29 today, slippery like an ice rink up in northern AB today. I'll run 29 for the week and see how she feels. I was at 32 before.
  7. Oct 25, 2010 at 9:05 AM
    Golfer83
    Golfer83 New Member
    Houston
    07 Tacoma TRD Double Cab
    Thankful to be living in Houston- high of 91 today
  8. Oct 25, 2010 at 9:16 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i agree, i drop my air pressure a few pounds in the winter.
  9. Oct 25, 2010 at 9:19 AM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    Yea there is a nice veneer out there on the snow this morning.....oh the joys of being a student in Edmonton.
  10. Oct 25, 2010 at 10:00 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
  11. Oct 25, 2010 at 5:37 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Do the chalk line test on the tires.
    this will give you the best wear pattern and best traction.
    the front and rear may vary with the bed being so light.
    I run 34psi front and 24 psi rear all year
    because those are the best psi for my tires on my truck
    and yes i know snow - buffalo!
  12. Oct 25, 2010 at 5:40 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    where are in northern alberta are you OP?
    ill be putting mine down to 25 shortly
  13. Oct 25, 2010 at 7:06 PM
    AlerAero
    AlerAero Equipment MFG
    Northern Vermont
    09 Tacoma V6 SR5 4x4
    BakFlip Folding Tonneau, Locking bed storage compartments, Bug/rock guard, Anytime backup cam mod, Hitch + wiring
    I maintian 30 psi over winter but i also got wider tires on wider rims for winter then my Dunflops on the stock steels
  14. Oct 25, 2010 at 7:10 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i always keep my tires at full pressure. i dont like floatation, im a skinny tire/ cut throught the snow kinda guy... i had a truck with 315/75s and it was f'n terrible in snow. i had another truck with 235/85s and you have way better traction. skinny tires at normal psi FTW!!!
  15. Oct 25, 2010 at 7:47 PM
    pcledrew
    BC
    '17 TRD Sport DCLB
    ttylerr
    I'm in Bonnyville. You?
  16. Oct 25, 2010 at 7:48 PM
    pcledrew
    BC
    '17 TRD Sport DCLB
  17. Oct 25, 2010 at 7:51 PM
    Yoytoda
    Roland
    completely stock
    go to a parking lot. chalk a line across the tire. when you drive forward a couple rotations it will wear the chalk off. if it leaves chalk in the middle tire pressure too low, if it leaves chalk on the outsides tire pressure too high
  18. Oct 25, 2010 at 7:56 PM
    skistoy
    Western New York
    Draw about a 1 inch wide chaulk line across all 4 tires.
    drive a short distance and then look at the lines.
    if the center of the line is worn more than the edges - too much air
    hense, if the edges are worn more than the center - not enough air.
    this may take several attempts, but keep track of what the tires psi are
    and also note how the truck drives and feels.
    you want a nice even wear on the chaulk line.
    the front and rear may be different due to the back end being lite.
    I run 34 psi front, 24 psi rear on my truck
  19. Oct 25, 2010 at 9:05 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    Do you tow anything with the rear at 24?
    I would think if you had to do a high speed maneuver with the tires that low, the truck wouldn't perform as intended.. My truck recommends 32 in the rear.
  20. Oct 25, 2010 at 9:08 PM
    Yoytoda
    Roland
    completely stock
    if you tow or carry things in the rear i would bump up the pressure from the chalk test. On my load e tires i run 40 all around. the rear tires are a bit high. chalk test reveled clean center. but i always wind up with a couple hundred pounds in the rear so i dont mind a bit higher pressure
