Winter Tire Changeover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by timkins42, Oct 7, 2023.
  1. Oct 7, 2023 at 7:27 AM
    timkins42
    timkins42 [OP] Well-Known Member
    Tim
    Fishers, NY
    2021 Black Tacoma 4X4 TRD Sport Access cab
    None so far
    Just changed the wheels and tires over for the winter driving experience. I am the 2nd owner of my 2021 Tacoma and think this is the 1st time the wheels have been removed as I had to take a BFH to the inside of the wheels to get them off. Is this normal?
  2. Oct 7, 2023 at 7:33 AM
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    Were there retaining clips on the studs? Rust and orosion holding it together? Why was it hard?
    I put some anti seize on the hub and rotate every oil change or two. Never have much of an issue on any vehicle I own.
    Stevie17 likes this.
  3. Oct 7, 2023 at 7:34 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    Must of been a buildup of rust or dirt. What shape were the tires when you bought the truck.
  4. Oct 7, 2023 at 8:07 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Guess they've never been rotated!
  5. Oct 7, 2023 at 8:43 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Galvanic corrosion…….its an issue with dissimilar metals. Its rather common
    Chew and Stevie17 like this.
  6. Oct 7, 2023 at 8:53 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Do you have the TRD Sema wheels? Those are never fun to remove. Those were a bear, but when I switched to the stock sport wheels they were super easy to remove and usually fall off on their own when I remove the last lug nut.
    The semas I pretty much had to get behind the wheel and kick it off with enthusiasm. Annoying.
  7. Oct 7, 2023 at 9:15 AM
    timkins42
    Tim
    Fishers, NY
    None so far
    I think it was galvanic style corrosion. There was only about 15K on the truck when I bought it, so that is what makes me believe they had never been removed before. I wire brushed the wheels and hubs and put on a small coating of anti seize for when they are removed and replaced on the spring.
    crazysccrmd and Stevie17 like this.
