Winter tire pressure
Discussion in 'Wheels & Tires' started by kiwiyyc, Dec 19, 2020.
  1. Dec 20, 2020 at 6:11 PM
    taco pops
    taco pops Well-Known Member
    Russ
    West Michigan
    2016 black SR5 Tacoma DCSB
    Side Steps, Tonneau cover
    i would set the air pressure at 30psi cold. It will loose air pressure during the cold months. MPG will suffer in cold temps also.
  2. Dec 21, 2020 at 8:51 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    wat?
    In the snow..
    32 is my sweet spot with 255/70R17 Blizzaks.. not to bumpy, still super grippy.
  3. Dec 21, 2020 at 8:52 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    :rofl:
  4. Dec 21, 2020 at 8:54 AM
    Bishop84
    Bishop84 Well-Known Member
    I've never seen dangerous hot air from a tire in all my years. Maybe from towing and free way driving.
    vicali likes this.
  5. Dec 21, 2020 at 8:59 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Hold on let me get my chalk out
    Charlie Too likes this.
  6. Dec 21, 2020 at 9:00 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Should be even easier with snow. I've used mud too
  7. Dec 21, 2020 at 9:03 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    on the highway? 24/7? wtf? thats way to low.
    its not rocket science. run what the recommended tire pressure says on the tire. You dont need to change it just because there is 3" of snow on the roads
  8. Dec 21, 2020 at 9:05 AM
    coopcooper
    alberta canada
    sorry waht.
    you know the number on the tire is the max operating psi.
    Dirk Diggler likes this.
  9. Dec 21, 2020 at 11:27 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    edited:santa2:
  10. Dec 21, 2020 at 11:35 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I run 29 psi. Dealership delivered my 2020 TRD Sport Premium to me with 40 psi all around which was fine in summer but gave me horrible traction in the snow and ice. Dropped it down to 29 psi and was fine. Took it in for first service and oil change and guess what... Back to 40 psi all around and terrible traction. Good thing I do not plan on going to the dealership for any future services. Kind of a liability for them to over inflate tires. Even the quick lube I worked at as a teen set the tires per the door placard!
  11. Dec 21, 2020 at 11:41 AM
    CalcityRenegade
    2023 T4R ORP KDSS
    Dealer set mine to 40 psi and I aired down to 29 psi when I thought it was could enough. I checked it again when very cold and was still around 35 psi. Very good example of this.
  12. Dec 21, 2020 at 12:00 PM
    BillsSR5
    bill
    2014 SR5
    air mine to 30psi cold they heat up to 32-33psi
    Hooper89 and Dirk Diggler like this.
  13. Dec 21, 2020 at 12:10 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I roll with the pressure on the door. I 've found I get the most even wear that way. I used to run higher, but it was crowning the centers out.
    BillsSR5 likes this.
  14. Dec 21, 2020 at 12:20 PM
    BillsSR5
    bill
    2014 SR5
    me too, I did the same, now I run the door jam psi
  15. Dec 21, 2020 at 2:42 PM
    #35
    jadatis
    jadatis Well-Known Member
    Peter
    Dont you mean 25 psi with that last 35 psi?
    In nex list I made 29 filled at 65 degrF, becomes 25 psi at 17 degr F. is below freesing point, so verry cold as you write.
    degr F. PSI
    5 24
    17 25
    29 26
    41 27
    53 28
    65 29 advice-pressure
    77 30
    89 31
    101 32
    113 33
    125 34
    137 35
    149 36
    161 37
    173 38
    185 39
    197 40
    209 41
    221 42
    233 43
    degr F. PSI
  16. Dec 21, 2020 at 2:45 PM
    #36
    CalcityRenegade
    2023 T4R ORP KDSS
    No. The tires were still warm so the pressure was higher than cold. Hence why when I checked the pressure when actually cold they were still higher than I would like.
  17. Dec 21, 2020 at 3:07 PM
    #37
    jadatis
    Peter
    Then it can only be that the measurements where inacurate.
    Edited a nice pressure/ temperature list, while you answered.
  18. Dec 21, 2020 at 3:45 PM
    #38
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    This gave me the best results with factory tires.
    BillsSR5[QUOTED] likes this.
