Winter Tire Pressure.
Discussion in 'South West' started by 881dcoupe, Dec 31, 2020.
  1. Dec 31, 2020 at 7:46 AM
    881dcoupe
    881dcoupe [OP] Member
    juval
    Midvale, Utah
    stock
    Super Sketchy drive this morning. What tire pressure yall run in winter??
  2. Jan 1, 2021 at 3:31 PM
    UT_Runner
    UT_Runner Well-Known Member
    Taylor
    N. Utah
    19 Auto, DCSB OR, 6112/5160, stage 2 deavers, 255/80/17, Snugtop, Cement
    Same as I run in the summer, 30-32
    881dcoupe[OP] likes this.
  3. Jan 1, 2021 at 3:33 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Same year round. 32 on all 4.
  4. Jan 1, 2021 at 3:41 PM
    PlatinumCloud
    PlatinumCloud Jameson Drinker
    Sarver
    2015 off-road pkg
    As the fellow before stated same as all year round. tire pressure doesnt effect much once your tires maintain a flat footprint. going lower only really helps flex and comfort offroad. your tire pressures should be found for your vehicle and weight considering tire mfg. if your having issues in winter with "sketchy" situations i would suggest adding weight over the rear axle, using gears to help slow and finesse on the go-go pedal. Also having real winter tires and/or fresh tires for winter is a good place to start!
    881dcoupe[OP] and RedWings44 like this.
  5. Jan 1, 2021 at 4:12 PM
    Stxxx
    Stxxx Well-Known Member
    2009 Tacoma TRD
    Where were you at OP? Or were you just out earlier than me? I run the same all year round.
  6. Jan 1, 2021 at 5:31 PM
    881dcoupe
    juval
    Midvale, Utah
    stock
    Yeah I was at about 35 on all 4. Brought them all to 30. When I went from second to 3rd the rear end wiggled outa place for a sec so I'll try adding some weight. Guess it didn't help that it was in the low 20s.
  7. Jan 1, 2021 at 5:43 PM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    Mine are running between 32 and 33.
  8. Jan 1, 2021 at 5:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    32 Front
    34 Rear
    I haul stuff regularly.
    We don’t get a lot of snow here.
    It does get into the low 20’s or Teens a few times per year at night.
  9. Jan 1, 2021 at 5:52 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Weight over the rear is key. If you're not off road, lowering (or raising) is going to hurt you more. Follow the recommended PSI listed on the B pillar unless you have something other than the stock tire size.
    881dcoupe[QUOTED][OP] likes this.
  10. Jan 4, 2021 at 7:03 AM
    881dcoupe
    juval
    Midvale, Utah
    stock
    Thank you all for the input. I appreciate it.
  11. Jan 4, 2021 at 7:10 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Did you change the air in the tires. Summer air isn't as dense as winter air.
    Bleed the tires down to about 3 psi, then fill with the winter air. Do the same when summer arrives.
    Seriously, same tire pressure year round. Look at the placard in the driver's door jamb. It will have the recommended tire pressure. One note, you will need to check the pressure as the air temperature changes. Falling temps will mean falling tire pressure. Rising temps = rising pressure. Adjust as needed.
  12. Feb 4, 2021 at 10:24 AM
    hockeynut258
    hockeynut258 Well-Known Member
    2019 OR MT
    I’d run the same. In deep snow, like when wheeling it helps to air down. Not recommend for the street..
    I run 30 F 28 R on duratac 265/75/16 load C all year. After the chalk test that got them closer to even wear on the back
