Winter tire PSI?
Discussion in 'Wheels & Tires' started by 45acp, Oct 2, 2011.
  1. Oct 2, 2011 at 8:49 PM
    45acp
    45acp [OP] Paint me back in Wyoming again...
    Jonathan
    Fort Collins, Colorado
    bone stock / unmolested 04 2.7L
    Quick question...
    I'm running Blizzaks during the winter. On packed snow and ice is airing down gonna help at all with traction?
    As I understand it, airing down helps with deep snow by creating a larger footprint. Was talking to someone the other day that said I should be keeping winter tires a little over-inflated for traction on ice.:confused:
    Which is it? What PSI should we be running on ice and packed snow?
  2. Oct 4, 2011 at 3:56 PM
    45acp
    Jonathan
    Must be a pretty good question.:D
  3. Oct 4, 2011 at 3:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I was always told the wider the tire, the worse traction you get. I heard skinnier tires are better for the snow cause they cut in better then wider tires do.
  4. Oct 4, 2011 at 3:58 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    For hard packed snow/ ice, I would think that a higher tire pressure would be better to decrease the footprint slightly and increase the pressure on the tread area.
  5. Oct 4, 2011 at 4:01 PM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    for hard packed snow/ice, i air down. fresh snow, skinnier track is better. my $.02
  6. Oct 4, 2011 at 4:52 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You either want tall and skinny or fat and underinflated. If you're sticking to roads, tall and skinny (normal pressure) is what you want. If you're going off the road and want to float then you want fat tires and underinflated. I normally run normal tire pressure all winter. If I have a long run that I know will be crappy or unplowed I'll drop the pressure a bit.
  7. Oct 4, 2011 at 5:22 PM
    45acp
    Jonathan
    Good deal, thanks for the help guys.
