winter tire size???
Discussion in 'Wheels & Tires' started by XREILLYX, Sep 26, 2012.
  1. Sep 26, 2012 at 7:28 PM
    XREILLYX
    XREILLYX [OP] Well-Known Member
    Reilly
    okanogan
    07 white double cab
    blacked out taillights, White OME 885X's, Billy 5100's around, added 120v/aux charger, Browning sticker!
    i am getting a set of goodyear wangler duratrac's and wondering if its better to get like 265's or 285's for winter driving????
  2. Sep 26, 2012 at 7:40 PM
    XREILLYX
    Reilly
    okanogan
    07 white double cab
    I have a leveling kit and I was reading up on here and apparently u can fit 285's with some trimming. But I am wondering how each one with Handle in the snow and ice
  3. Sep 26, 2012 at 7:41 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    id go 285..
    Edit:
    old pic with 285's
  4. Sep 26, 2012 at 7:43 PM
    DitchDoc
    DitchDoc Well-Known Member
    Logan
    Western North Carolina
    03 V6 QC TRD Limited 4x4
    2003 DC 4x4 TRD Cap K&N FIPK
    I would go 265s. A wider tire will float a little more on snow where a thinner one will help cut through it.
  5. Sep 26, 2012 at 7:45 PM
    XREILLYX
    Reilly
    okanogan
    07 white double cab
    So will 285's Handel the ice good? And what size is 285 in inches
  6. Sep 26, 2012 at 7:48 PM
    Blacktacoma23
    2011 Mall Crawler
    True
    Duratracs do great in snow, 285's usually near a 33
  7. Sep 26, 2012 at 7:55 PM
    whammond
    whammond Member
    Will
    Eugene, Oregon
    07 DCSB Trd Sport 4wd
    3 Inch Revtek Lift
    I'd go with 265s for snow. A 285/75/16 or 285/70/17 is close to a 32x11.50 and 265/75/16 or 265/70/17 are close to a 31x10.50
  8. Sep 27, 2012 at 4:15 AM
    VTTACOMA
    VTTACOMA Well-Known Member
    Benj
    Vermont
    TRD Sport, Black
    I used to run a BFG M/T 255/75 on a stock 17" and it was awesome in the snow.
  9. Sep 27, 2012 at 6:02 PM
    XREILLYX
    Reilly
    okanogan
    07 white double cab
    yea i am going on my stock rim think the 265's will rub anywhere?
  10. Sep 27, 2012 at 6:19 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    I ran 265 75 16 on a stock suspension last winter with no issues.
  11. Oct 1, 2012 at 1:57 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    My Blizzaks are 265. Next time I will get 255 in a larger diameter. If you are running through deep snow, tall and narrow is the way to go!
  12. Oct 1, 2012 at 8:28 PM
    whammond
    whammond Member
    Will
    Eugene, Oregon
    3 Inch Revtek Lift
    I agree. Taller, narrower tires cut through the snow better than a wide tire in most situations. However, narrower tires do not perform in ice as well as a wide tire would IMO.
  13. Oct 2, 2012 at 7:41 AM
    XREILLYX
    Reilly
    okanogan
    07 white double cab
    What size off set on your rims?
  14. Oct 2, 2012 at 12:28 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    Try 235/85R16 or 235/80R17. Awesome tires in the snow.
  15. Oct 29, 2012 at 6:13 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Wider tires are better for float... So mud, sand etc.... For winter driving you want a smaller surface area on the road. This results in more pressure therefore cutting and holding on snow and ice better. So a 265 would hold better than a 285. And wider tires would NOT hold better on ice. It's physics....
  16. Oct 23, 2013 at 8:00 AM
    jd17usmc
    jd17usmc Well-Known Member
    jansen
    Gainesville, FL
    2012 TRD Sport 4wd doublecab grey 6 speed
    Bilstein 5100 all around to level it out.
    i love the profile of this truck! great look!!
