Winter Tires & Wheel Sensor
Discussion in 'Wheels & Tires' started by Big Ring, Dec 17, 2012.
  1. Dec 17, 2012 at 6:12 AM
    Big Ring
    Big Ring [OP] Active Member
    Ottawa
    2013 magnetic grey Tacoma SR5
    Just put my winter tires on my 2013 double cab SR5 - Blizzacks on OEM steel rims. Tires are the same size as the stock Dunlops.
    Problem: the wheel/tire sensor on the console came on. Why is this happening? I recall reading somewhere once that the sensor would come on but I was assuming if you were using different sized wheels/tires. Air pressure is set correctly.
    Thanks for reading.
    Cheers
    Big Ring
    P.s. My first post since getting my baby! Will post up some photos and what I've done already. Have a metric shit tonne of questions on stuff I'd like to do - my first truck and I don't know shite! Cheers!
  2. Dec 17, 2012 at 6:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Welcome!
    There is a TPMS reset button below the steering wheel. Press and hold that and it should turn the dash light off (assuming the sensors are still in the wheels that you are currently running).
    Before you ask your metric shit ton of questions, try reading your Owner's Manual :)
  3. Dec 17, 2012 at 6:42 AM
    Big Ring
    Ottawa
    Bahahahaa! Thanks Pugga! I was wondering when I'd get flammed . . .
    Yep, knew about the reset switch, but I was more interested in WHY it was doing it considering the tires are the same size as stock. Any insight?
    I've been lurking this boards for enough time now to do a search before asking a question . . . man, you Tacoma owners hammer the NOOBS for asking questions! LOL - all good fun.
    Thanks for reading & Cheers!
    BR
  4. Dec 17, 2012 at 6:50 AM
    Pugga
    Massachusetts
    It happened because the pressure essentially dropped to 0 when they took the old tires off. That triggers the ECU to throw on the dummy light. Then, even if everything is set back to normal, it doesn't automatically reset itself.
  5. Dec 17, 2012 at 8:08 AM
    Big Ring
    Ottawa
    Crystal clear - cheers!
  6. Dec 18, 2012 at 9:49 AM
    DEX
    DEX New Member
    DEREK
    GRESHAM
    TACOMA 4X4
    IF YOU CALL IT A MOD...CANOPY
    ACTUALLY MY MANNY PRETTY MUCH ASSUMES I'M A SOCCER-SALLY AND SAYS IT DOES RESET AUTO. IF NOT TAKE IT TO $DEALER$ SO I RESET IT MANUALLY FROM UNDER THE DASH. BUT IM WONDERING (BECAUSE IT CAME BACK ON) IF THERE IS A CODE ASSOCIATED WITH IT, THAT ELABORATES ON THE MALFU%$TION LIKE A ~KOER~ OR SOMETHING
    TIPS?
    ADVICE?
    OR CRAP TO SLING @ THE NEW GUY?
  7. Dec 18, 2012 at 10:05 AM
    Pugga
    Massachusetts
    If all the tires are properly inflated, and you've reset the system correctly and the light continues to stay on, you might have another issue such as a bad sensor. Depending on what year your Tacoma is, you might have a sensor in the spare tire which you should check also. I believe 2005 through 2008 or 2009 have sensors in the spare. I'm not sure how the ECU operates as far as throwing codes if the TPMS system is not functioning properly. As far as I know, the only thing you see is the light on the dash if there is a problem. I believe it will blink if there is an issue with a sensor vs. just a low reading but I'm not 100% sure on that.
