Winter tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Truck Chick, Nov 2, 2012.
  1. Nov 2, 2012 at 12:01 PM
    Truck Chick
    Truck Chick [OP] Active Member
    Lauren
    California
    '13 Tacoma
    Hello ladies and gents! I recently moved to the New England area a few months ago and am preparing for my first winter living/driving in snow. I have been doing research for snow tires for my 08 Tacoma PreRunner 2x, and from the shops/people I have talked to I can't seem to get a great answer. So far my choices are Mastercraft Courser, Firestone Winterforce, and Bridgestone Blizzak but am open to more suggestions. I am also debating getting four or just for the rear tires (since I don't have 4x4) and also studs on them. I am NOT looking for the cheapest tire out there-I am a firm believer that you get what you pay for. Any other suggestions/advice would be great! Thank you!
  2. Nov 2, 2012 at 12:08 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Where in new england? I would say studs would not be necessary in some parts of new england. Sorry i cant really help you out with the tires, i never run snow tires even when i lived in vermont.
  3. Nov 2, 2012 at 12:21 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    You should change your thread title to something like new girl needs winter tire advice, you would get alot more responses lol. Welcome to TW by the way.
  4. Nov 2, 2012 at 12:25 PM
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    snow tire advice...
    depends on if you wanna run studded tires
    if not a good A/T works but since your 2 wheel drive keep a shovel in your bed along with a few sand bags to keep the rear end heavy. Drive slow/carefully, don't pin it to win it.
    If you decide to run studded snow tires also put sandbags in the back of your truck.
  5. Nov 2, 2012 at 12:31 PM
    badger
    badger Well-Known Member
    07 SR5
    Whatever you get, make it 4 not 2. You don't want a situation where either end has compromised traction. You need steering, brakes, and power.
    Most of the winter tires I have run used studs, so the studs did most of the work. If I needed winter tires again I would look at either the Blizzack or the Hakkapeliitta (Nokian) studless. I have run the Nokian before and they are very good.
  6. Nov 2, 2012 at 1:00 PM
    badger
    07 SR5
    One nice advantage to studless tires is that you can put them on early and take them off late if need be. I swear, the deadline for stud removal ALWAYS came just before the last big storm of the year. Even the sheriff's dept ignored the deadline one year.
    I might add that studless tire technology has made huge leaps in the last 10 years. The early attempts gave a lot of people a bad attitude toward them. Take another look............
    I generally only got 2 seasons from my studded tires because the studs ripped out. I bought a stud gun and started restudding, but it was a pain. Below a point you couldn't restud at all.
    I think the studlees tires made today are better than studs in many circumstances. There are only a few specific instances where real studs have any edge.
  7. Nov 2, 2012 at 2:38 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    This is good advice. Where in New England are you? I know you have a 2 wheeler but a good set of all season tires might work for you also, I have ms2's and have gotten by pretty well the past two years, but there where a few times where I put it into 4hi
  8. Nov 2, 2012 at 2:51 PM
    Carlemil
    Carlemil Member
    Ontario
    12 DC V6 SR5
    Not a good idea to mix tires. Once on borrowed truck, I went into ugly spinning on the road when driving mixed tires in snow. The non-winter tires slid while the powered wheels pushed me into spinning because those had better traction. Fortunately, I was not driving fast. Not sure if the new traction control systems would manage to compensate for that.
    I drove studs for couple winters when I lived closed to arctic circle, and the studs will only help you on ice. The studless will work on ice & snow because of the combination of compound they are made off and the tread. The studded ones work primarily because of studs, and the compound and tread are secondary (and not so good, quite often cheap version) and designed for holding the studs. So when you lose studs or drive in deep snow, you rely on compound & tread which is not that good. If you have good feeling for car behavior, you don't need studs even if you haven't driven on snowy road before. They are for really bad snow drivers :)
    When shopping for winter tires, I check e.g. Tirerack.com surveys:
    http://www.tirerack.com/tires/survey...p?type=W&VT=LT
    The other online shops have usually similar "ranking". This gives you an idea of comparisons between various models. For this winter, I am going with Continentals 4x4 Wintercontact, quite good ranking ... and I ran into sale.
  9. Nov 2, 2012 at 3:16 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    first off welcome to new england and tw..id suggest you get the blizzaks. i know a few two wheel drive owners and they swear by them here in massachusetts. and yep id get a set of spare wheels to mount them on so you dont have to keep swapping wheels...snow will come and who knows when is always the real question
  10. Nov 2, 2012 at 10:05 PM
    Atomic47
    Atomic47 Well-Known Member
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Leveling kit, AAL, air-ride, Rear diff breather mod, Illuminated 4wd Switch, 4 more D rings, fog lights anytime, 7 pin relocate, Coca-Cola mod, TRD Off-Road hook, Weathertechs, secret custom cargo light, 09 lower dash panel, heated seats, 2013 oem touch screen radio, reverse camera added into Pop'n'Lock locking tailgate handle, black powder-coated TRD Sport rims, 32" light bar in custom fabricated mount, aux reverse lights in rear bumper
    Definitely invest in 4 tires not just 2. I can't say enough good things about the Nokian Hakkapeliitta 5's that I bought 2 years ago. Fantastic traction! They weren't cheap but as you said, you get what you pay for.
  11. Nov 2, 2012 at 10:06 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Hankook makes some great ones too. Bout the only thing I trust coming out of korea.
  12. Nov 2, 2012 at 10:06 PM
    benbacher
    Anchorage, AK
    Except for Koreans of course. :)
  13. Nov 3, 2012 at 12:43 AM
    Biodegradable
    Biodegradable Well-Known Member
    Winnipeg
    10 4x4 SR5 DBLC LB
    ALL-PRO Skid, Nokian R-SUV winters, weather tech, bak flip fibermax
    One of the best tires you can buy for winter tires, Nokian R SUV. Finnish mountain tyre as they say it. Non studded. They cost $$$ but are the best.
  14. Nov 3, 2012 at 6:13 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I have Michelin X-Ice's on my truck. They are great on ice and packed snow, which I find most road driving is. Nice and quiet as well. For really deep snow I would get something more aggressive.
    I too believe in getting 4 tires as opposed to just 2 as it balances out the handling.
    Shawn.
  15. Nov 3, 2012 at 6:47 AM
    Azntrutek
    Azntrutek Well-Known Member
    ATL
    08 TRDsport -Towpackage
    2".5 lift, HID head lamp and HID lights, color match tonneau cover and running board.
  16. Nov 3, 2012 at 6:54 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    A close friend of mine used to believe in buying 2 at a time to lessen the cost shock. When he bought a nicer car than his first clunker he did just that. Well, a couple months later he had 3 spinouts in less than a week. That weekend he bought the other 2. Lesson learned.
  17. Nov 3, 2012 at 11:10 AM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I can't wait to get my General Grabber At2's in the snow.
    After reading many raving reviews on the tire in the wet/snow i bought a set. I have to say I am very impressed with the tire in the heavy rain we have had. They are quiet on road and have no hum.
    They have the snowflake rating and are studable.
  18. Nov 3, 2012 at 12:08 PM
    Truck Chick
    Lauren
    California
    '13 Tacoma
    Thank you for all of the help guys! I am definitely planning on putting sandbags in my bed, but how much? About 100lbs? More/less? I will now plan for four tires and am wondering if anyone has any input for Town Fair Tire? They look like they have a pretty nice "included" service package when purchasing tires.
  19. Nov 3, 2012 at 12:58 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    You couldn't go wrong with 200-300 lbs. 100 won't make much difference - I'd be surprised if you noticed it.
    You can also go for a narrower tire for better traction. If you're running 265/75/16, switch to a 235/85/16.... If you're running 265/70/16, switch to 245/75/16.
    Both switches would give you approximately the same height, but about an inch narrower.
    I do a LOT of driving on terrible winter roads in Canada (and in remote locations) for work and this setup works well for me.
    Good luck. Drive safe.
  20. Nov 3, 2012 at 1:49 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    In the past, I have used Blizzaks, Nokians, Firestone Winterforce Studded, General Altimax Arctic (which is a Gilslav Nordfrost made my Continental) on my trucks.
    I have also used a snowflake rated AT tire Goodyear Silent Armor.
    Personally, I have preferred a dedicated snow tire.
    Just put a set of Hankook Ipike RWs (studded) on my Tundra but you do not have to get them studded. I tow however & see a lot of ice since Vermont has started using brine more & more.
    The nice thing with the Blizzaks is once the special sticky compound wears down you can then run them year round.
    Many people do that here in Vermont.
    As the guys said I would buy 4
