Winter tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Korby, Nov 13, 2021.
  1. Nov 17, 2022 at 2:49 PM
    #101
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    Blizzak DM-V2 . Have Used the different variations of these tires for many years o different vehicles and they are always solid tires. I put mine on in November and take them off 1st week of April. I get typically 5 winters out of a set of 4 with regular rotations and making sure i don't forego getting an alignment when it's needed and alignment checked every time i get it serviced and proper inflation of course. 4 winters is optimal for a set of these tires but you can push it to 5 but at the end of the 5th winter it's pretty clear their best days are behind them and you need a new set.
    BOMBS, rainsux and Intrepid like this.
  2. Nov 17, 2022 at 4:03 PM
    #102
    Kllrbee
    Kllrbee Well-Known Member
    Tim
    Bloomfield, WI
    22 Army Green DCSB Sport
    Thnx bud, thats the info I was looking for.
    ExGunner[QUOTED] likes this.
  3. Nov 17, 2022 at 4:46 PM
    #103
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
    My Blizzaks were the first set of tires on my truck when I picked it up new in February 2018 in Whitehorse, Yukon. Only ran them about 4000Ks that first winter all in the Arctic. The tread wear in colder climate is almost unnoticable. Every winter since I've run them about 8000K in Toronto and Montreal. I wait as late as possible before putting them on in the city and I'm very careful to get them off the truck when the temperature starts to rise. This might be the last winter I get out of them but their performance hasn't dropped even with an 18 year old using the truck most of the time.
  4. Nov 17, 2022 at 5:15 PM
    #104
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I just got my current Taco. It's a new off road premium. Had a 2016 trd sport before. The new one has General Tire Grabber AT. We have snow and ice on the roads here and so far no problems. Never took it out of 4hi. Plan to keep on for the summer.
  5. Nov 17, 2022 at 7:59 PM
    #105
    Intrepid
    Jeff
    I don't have a lift so I got my Blizzaks in OEM 265/65/17. I since got a set of Kumho MT tires in 265/70/17 that give the truck a nicer stance even with factory suspension. My Blizzaks might need replacing after this winter and I've wondered about going a bit bigger with the replacements but I've read that winter tires and rims should go down a size. I think I'll choose better aesthetics of taller skinny tires for my next winters over whatever marginal gain a smaller diametre manages.
  6. Nov 17, 2022 at 8:30 PM
    #106
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    I live is a heavy snow state. I gave up on tire swapping and just run Goodyear duratrac year round.
  7. Nov 18, 2022 at 8:32 AM
    #107
    DetroitZoran
    DetroitZoran Member
    2017 DCLB Silver
    Those of you that run a separate set of winter tires, do you bother with TPMS or no?
  8. Nov 18, 2022 at 9:53 AM
    #108
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Don't bother with TPMS on my Blizzaks on FJC steelies. I park close enough to my summers that the light only goes on after 30 minutes of driving out of town.
    Winters make the difference between tip-toeing around in snowy icy conditions, and just getting there. Blizzaks don't spin, no ABS lights, no TCS cutting in, none of the nannies get excited- you just go where you point the truck.
    Insomnivore and Intrepid like this.
  9. Nov 18, 2022 at 3:04 PM
    #109
    ExGunner
    Paul
    I bought TPMS sensors for my winter rims and ive been running on the same ones for going into 6 winters. I know many don't use TPMS sensors on winter tires because of the cost and just ignore the warning light but i thought it was worth the money. I bought aftermarket ones and not OEM ones and haven't had an issue.
  10. Nov 18, 2022 at 3:08 PM
    #110
    eurowner
    eurowner Duke Sky
    Scoty
    I use clone Autel 315MX sensors to the OEM sensor ID#s in my other wheels so the truck only knows/sees the same 4 ID#s.
  11. Nov 18, 2022 at 4:41 PM
    #111
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    Same here.
  12. Nov 18, 2022 at 6:27 PM
    #112
    Intrepid
    Jeff
    What state doesn't get above 45 degrees Fahrenheit in summer?
  13. Nov 18, 2022 at 6:28 PM
    #113
    Intrepid
    Jeff
    I don't have TPMS.
  14. Nov 19, 2022 at 11:11 AM
    #114
    MTBTACORN
    MTBTACORN Well-Known Member
    Ontario, Canada
    23 Tacoma TRD Pro 21 Sportster S
    Currently running Hakka SUV R2s on my 4R as well for a few years now and I can't say that I would ever purchase them again. I feel they drift or float too much and don't offer the best traction during stopping. They are great on freshly plowed hardpack but not very good on anything else. I seem to be in the minority on this. I'm running them in stock size and really just waiting for them to wear out so I can replace them but they will most likely go on my Taco that should be arriving Decemberish.
    I had a set of Yokohama Geolandar I/T G072s on my 2nd Gen Taco in a 245/75R16 that were incredible.
  15. Nov 19, 2022 at 12:36 PM
    #115
    rainsux
    rainsux Well-Known Member
    2021 Tacoma Off Road
    None.
    Love my Blizzaks. Yes, I run TPMS on my winter tires.
  16. Nov 19, 2022 at 1:52 PM
    #116
    SoonToBeOn39s
    SoonToBeOn39s Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Studded duratracs are the way to go
  17. Nov 20, 2022 at 10:36 AM
    #117
    WannabeMechanic
    WannabeMechanic Member
    23 tac0o offroad
    i am running continental vikingcontact 7 winter tires in 245/70/16. They are pretty awesome, very quiet tires and so far its the best winter tires ive had
  18. Nov 23, 2022 at 6:27 PM
    #118
    DJR81
    DJR81 Well-Known Member
    2013 5 lug 4 speed auto
    Do you do ok in 2wd in snow with the duratracs? Looking for a do it all tire for my 5 lug. In central VA so maybe 2-3 days of snow driving. Next option is getting 2 more steel wheels with winter tires on the rear (Hercules avalanche RT)
  19. Nov 24, 2022 at 4:53 AM
    #119
    Rraiderr
    Great White North
    Working now a list
    Minnesota only gets a few months of +45F weather, the rest is cold and snowing.
  20. Nov 24, 2022 at 8:03 AM
    #120
    Boomchase_N
    Boomchase_N New Member
    JDaniel
    2017 Tacoma TRD Offroad
    When I bought the off-road I had the stock Goodyear wrangler kevler.. which were good, but I don’t like Goodyear tires. I got the Michelin LTX AT/2’s after 27K,which were great in light trails, snow, rain, and highway. Phenomenal wear! Great gas mileage! They are not made for the 16’s anymore. But recently I got the BF Goodrich All Trail Terrain TA now at 89K, great gas mileage, excellent handling, balance, and grip. Not much difference in weight compared to the Michelin’s. Can’t wait for the ultimate test of snow. Awesome price at Costcos.
