Winter Wheel Recomendations
Discussion in 'Wheels & Tires' started by silverarrow, Jul 17, 2023.
  1. Jul 17, 2023 at 6:48 PM
    silverarrow
    silverarrow [OP] Active Member
    Vermont
    2020 TRD Off-Road
    OME Heavy Duty Lift
    I recently upgraded to really nice Icon alloy 17s and I'd rather not run them during the new england winters. I plan to get some nice winter tires but don't need anything fancy for the winter for the wheels.
    Does the offset of the winter set have to be the exact same as the summer set? Does everyone get an alignment with every wheel change?
  2. Jul 17, 2023 at 7:35 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    what'd you do with the original set? Just use them with winter tires.
    The two sets don't have to be the same and you don't need an alignment every swap.
    DavesTaco68 likes this.
  3. Jul 17, 2023 at 8:48 PM
    silverarrow
    Vermont
    2020 TRD Off-Road
    OME Heavy Duty Lift
    I already sold my old 16 wheels to pay for more new truck parts. I got the feeling that if the wheel offsets are different you needed a new alignment.
  4. Jul 18, 2023 at 2:10 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    You don’t need a wheel alignment swapping wheels, I’d pick up some oem wheels for cheap for the winters.
    eurowner and doublethebass like this.
  5. Jul 18, 2023 at 7:13 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Just make sure that you get four clone TPMS sensors, Autel 315mx, to use the sensor ID# that the truck has stored and read off your summer wheels.
    And an extra set of wheel nuts to fit whatever your winter wheels are.
    silverarrow[OP] likes this.
  6. Jul 18, 2023 at 7:27 AM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Just get some basic steelies in the same size and offset if you want a cheap set of wheels that will just work.
  7. Jul 18, 2023 at 7:47 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    In theory your wheel offset will affect your scrub radius which is (kinda) compensated for via camber during an alignment
    But in reality if you want to be picky just align it with your summer set and forget about it unless you have an issue. I have access to and the ability to do my own alignments but I'd never bother going through the trouble of aligning for seasonal wheel change overs and see it as a waste of money to pay for such a task to be done
  8. Jul 18, 2023 at 11:04 AM
    silverarrow
    Vermont
    2020 TRD Off-Road
    OME Heavy Duty Lift
    I haven't been able to find any cheep steels with a 0 offset. I like the Liquid Metal Atoms but their offset is 41. They are cheep and look ok enough for just winter.
  9. Oct 4, 2023 at 3:05 PM
    silverarrow
    Vermont
    2020 TRD Off-Road
    OME Heavy Duty Lift
    I've been searching for a while and still have been unable to find a set of wheels that will fit my truck at close to the stock offset. My hope was that my winter wheels would be the ones to pass inspection as my 'normal' wheels stick out slightly. I've spent hours using google and looking through various websites. Either no one makes a basic steel wheel for a 2020 offroad tacoma close to a 30mm off set. or I have no clue how the internet works.
  10. Oct 4, 2023 at 5:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
  11. Oct 10, 2023 at 5:59 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Toyota makes that exact wheel. It’s the spare on most trims.
  12. Oct 10, 2023 at 6:06 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
