Winterization for Cleveland
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 15tacomaTRD, Jul 30, 2015.
  1. Jul 30, 2015 at 5:59 PM
    15tacomaTRD
    15tacomaTRD [OP] Well-Known Member
    NE Ohio
    2015 Tacoma TRD Off Road
    Hey group-
    First time Tacoma owner - love my 15 TRD Off Road, great truck so far. Im looking for some advice/past experiences on winterizing (rust prevention). i live in Cleveland OH were salt is EVERYWHERE for 9mths of the year. I have read about various undercoatings and haven't heard many positive results over the long haul. I know from experience the black rubbery stuff you can get at places like Ziebart are junk because they seem to split and crack in colder climates, letting salt in. I have also read about the Honey Coat stuff too, but haven't heard much about its long term results. Im leaning toward using some heavy duty oils like Aimsoil HD Metal Protector or even PB Blasters rust preventer, and just applying it periodically to keep the rust at bay.
    So If anyone has any suggestions for what has worked/not worked, please fill me in.
    If theres all ready a thread on this, sorry, I'm new here.
    Thanks y'all,
    Vic
  2. Jul 30, 2015 at 6:04 PM
    cartage1
    cartage1 Well-Known Member
    Cleveland, Oh
    TRD, Sport
    No winterizing advice, other than to move, but welcome to TW from Westlake, Oh.... I look forward to any advice as well.
    savedone likes this.
  3. Jul 30, 2015 at 6:19 PM
    Fishtaco15
    Fishtaco15 New Member
    2015 Tacoma TRD sport
    I'm in the same boat. Have a 2015 TRD sport and really want to prevent rust this winter as I live in NY where they heavily salt the roads.
    So far from what I understand it's wash the underneath weekly and maintain the chassis and underbody with something like fluid film.
    What I've been thinking of doing is coating the chassis in POR 15 FLEXCOTE as it is something that can go over painted surfaces and was designed for marine applications where there is heavy salt spray and then also doing, a twice a year application of fluid film.
    Also stay away from heated garages.
    buzzkill911 likes this.
  4. Jul 30, 2015 at 7:26 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    2008 Tacoma. I power wash frame - let it dry for a day or so - spray with boiled linseed oil - no rust - many others in my area have had their frames replaced.
  5. Jul 31, 2015 at 5:21 AM
    Pigpen
    Dan
    Northwest Montana
    Rinsing it frequently will be the best solution, until you can move. (Former NE Ohioan here...)
  6. Jul 31, 2015 at 7:15 AM
    709GADE
    709GADE Well-Known Member
    '09 Toyota Tacoma 4X4 SR5 DC LB - Pyrite Mica
    Toyota aluminium side steps, Toyota door sill protectors Extang trifecta tonneau cover, U-Haul Class 3 hitch, Black Weathertech's, Front mudflaps trimmed 4", OEM Fog Lights, WeatherTech Bug Deflector, 13" Stubby antenna, TRD Skid Plate, ScanGaugeII, Carriage Works Billet Grille, Plasti Dipped overhead temp/compass console, LT265/75/16 Duratrac's LR C
    I've learned that rust is unstoppable, just enjoy your truck! If you stress and try to stop rusting you will not benefit, but the person you gets your truck from you when you sell it will benefit immensely. I've learned about this since I bought my truck in 08 and tried a lot of things to stop rust, hasn't really worked. I've given up and now I am just enjoying my truck.
    TacomaMike37 and buzzkill911 like this.
  7. Jul 31, 2015 at 7:19 AM
    buzzkill911
    buzzkill911 Desk pilot
    Buzz
    Colorado, USA
    2015 Blue DCLB 4x4 V6
    Wheels, tires, mud flaps, etc.
    This is what I plan on doing with my new 2015 facing an upcoming Wisconsin winter.
    This is also great advice - use it and enjoy it. Save the worry for something else, like work!
  8. Jul 31, 2015 at 9:13 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    from the rust belt of southern ontario. undercar oil spray. my mechanic does the frame and all doors, tailgate etc., every fall.
  9. Jul 31, 2015 at 9:39 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I've heard of guys that spray and get rust. Have heard of guys that spray and dont get rust . Have also heard of guys that dont spray and dont get any rust ( that being me and my father in law, both in the salt belt). THink the rust thing is wayyyy overblown on tacoma world.
  10. Jul 31, 2015 at 11:27 AM
    VermontTaco
    VermontTaco Well-Known Member
    Vermont
    2015 DCSB TRD Sport Silver
    Weather Techs Mats front and rear, Wet Okole seat covers, BakFlip Fibermax tonneau cover, Power Pop N' Lock, Flyzeye interior lights, Scangauge 2, IMMRYO Rearview mirror bracket, upgraded Homelink, temperature gauge, and compass rear view mirror, Matt Geko bed lights, OEM bed mat, Beerad's Antidark engine lights, interior LED lights, TRD SEMA 17" Wheels in gunmetal gray, LT265/70/17 BFG KO2 Load Range C, and center console/glove compartment organizers.
    I live in northern Vermont and we get our share of snow and salted roads. I read through the rust preventative measures suggested on TW and decided to get my brand new truck treated with Fluid Film. The FF worked great and I plan on having it done again this fall before winter. It's just a piece of mind for me as I plan on keeping my truck for the long haul.
  11. Jul 31, 2015 at 11:29 AM
    TacomaMike37
    13' DCLB MGM
    You do it yourself or you have someone do it for you. Mind me asking how much if you pay for someone to do it?
  12. Jul 31, 2015 at 11:42 AM
    VermontTaco
    Vermont
    It was the middle of winter in Vermont when I bought my truck so I paid a local shop to do it. It costed me $90 and the pressure washed the underneath the night before and let it dry. They then undercoated the truck the next morning.
    You can buy a kit that includes a sprayer and gallon of FF for ~ $100. That would last you a long time. I bought a few aerosol cans of FF from Amazon to do some touch ups of the high traffic areas. FF is good stuff. You should read up on it.
  13. Jul 31, 2015 at 12:07 PM
    TacomaMike37
    13' DCLB MGM
    Im on the beach all the time with my truck. From what I have read fluid film plus sand is a no go.
