Winterizing my 4x2 taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caliph420, May 21, 2017.
  1. May 21, 2017 at 11:02 AM
    Caliph420
    Caliph420 [OP] Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    Going to be moving to the very edge of north west WA and going through at least this winter in my truck 4x2 4c AC 2016. Hopefully trade in for 4x4 sometime next year.
    Looking for winter advise and maybe tips from anyone who knows the area of Clallam County
    (and yes I'm aware I should have bought a 4x4 :thumbsup:)
    So based on my research:
    1) Go slow
    2) Put weight in the bed, is 250 lbs of sand bags enough in a wooden frame centered over the axel or should I add more? like 400 lbs
    3) Winter tires? Brands with or without studs? (Studs might be overkill) I am open to throwing a set of steelies -TPMS with winter tires on the truck if will make a big difference
    4) Prob going to do some fluid film on the underbody because of the salt up there
    I have chains, track grabber and a come along winch with tow straps onboard
    Not sure how much chains in the rear do if anything for a 4x2
    Anything I'm missing?
  2. May 21, 2017 at 11:03 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Unless you're in the higher elevations over 1000ft sea level you won't get much snow. Just drive the truck like you normally would. It's a mild climate there. It rarely snows there at sea level.
    Caliph420[QUOTED][OP] likes this.
  3. May 21, 2017 at 11:06 AM
    Caliph420
    Washington
    I drove a rear wheel drive infiniti suv there for a week peak of winter with no issues till I went off on a side residential street which had 1.5 inches of solid ice over the whole damn street like a skating rink, that was fun. I am prob going to be driving the 112 or 101 around crescent lake to Port Angeles everyday for work about 55 miles
  4. May 21, 2017 at 11:06 AM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Skinny winter tires. 235/85r16 would be quite effective. And lots of weight in the back.
    I used to drive a 2wd Mazda truck before my taco. 600lbs in the back and I could drive up some hairy stuff. Steering suffers a bit with the weight in the back. Make sure to place the weight over the axle to minimize this.
  5. May 21, 2017 at 11:08 AM
    Caliph420
    Washington
    I got a frame made up to put sand bags in over the axel I use when off roading so I can fit prob 350+ in there no prob
  6. May 21, 2017 at 11:08 AM
    smitty99
    Scottsdale
    I grew up there 19 years of my life ....it just rains a lot. Never needed anything special to get around. My grandpa had an old Buick with rear wheel drive and had a set of snow stud tires (in the 80s) that he maybe used once or twice a year. Really not a necessity. If you drive into the mountains you're going to want 4x4. Really this is a non issue "winterizing " for northwest Washington. It is NOTHING like the northeast and you're not moving to anchorage.
  7. May 21, 2017 at 11:09 AM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
  8. May 21, 2017 at 11:10 AM
    Caliph420
    Washington
    Well thats good to know
  9. May 21, 2017 at 11:11 AM
    smitty99
    Scottsdale
    Buying snow tires for Port Angeles or Forks is like buying mud tires to get around in Phoenix AZ. If you plan to offroad 4x4 would have been far more useful anyhow.
    Caliph420[OP] likes this.
  10. May 21, 2017 at 11:11 AM
    Caliph420
    Washington
    That was last trip middle of winter, but I guess its been unusually large snowfall
  11. May 21, 2017 at 11:13 AM
    smitty99
    Scottsdale
    You must have been there for the one or two days it snowed last winter.
  12. May 21, 2017 at 11:13 AM
    Caliph420
    Washington
    4x4 was on the agenda, even ordered one, ha then my truck dropped 2600 in book value as this diff recall hit and that f'ed my plan, next year for sure, so tired of drooling at this site wanted to go further and use a truck to is potential, SOON!
  13. May 21, 2017 at 11:14 AM
    Johnny919
    Long Island, NY
    I'm not familiar with the area, not sure how much snow he will be getting there if any, just trying to help.
    Obviously 4x4 is the best solution and op already mentioned he's aware he should have got it.
  14. May 21, 2017 at 11:14 AM
    Caliph420
    Washington
    Haha I totally was... well Im glad its a lot less of a harsh winter climate
  15. May 21, 2017 at 11:15 AM
    Caliph420
    Washington
    I think I'm going weight in the back and see how it goes. I bet the forest roads out there are always muddy so you cant get away with a 4x2 like you can here in the desert
  16. May 21, 2017 at 11:17 AM
    smitty99
    Scottsdale
    tomwil likes this.
  17. May 21, 2017 at 11:18 AM
    Caliph420
    Washington
    I wish I was moving there first. I am going to be in Clallam Bay for a year or two while we get settled, then PA once we buy a house
  18. May 21, 2017 at 11:19 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    My truck is 4WD, but I spend most of the winter in 2WD. About the only time I needed 4WD was during really bad storms or occasionally to get up my driveway because it's long and steep and became a solid sheet of ice. Even then it wasn't necessary very often.
    For tires I run Bridgestone Blizzaks, DSM-V2 in stock sizes. Not sure why anyone would run skinny tires in the winter; you need traction and the more tire on the ground the more traction you get.
    That said, based on the local climate I don't think you really need to do anything special. Tires might give you peace of mind, but they probably won't be necessary.
  19. May 21, 2017 at 11:19 AM
    smitty99
    Scottsdale
    Go do some salmon fishing while you're there. Also the Dungeness crab and oysters are second to none.
    Check out the Olympic National Game Farm. You drive through and feed the animals from your car. A kick in the pants especially for kids.
    http://olygamefarm.com/
  20. May 21, 2017 at 11:20 AM
    Caliph420
    Washington
    You guys recommend a good dose of fluid film on the under body?
