Wiper arm pressure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomach2, Apr 5, 2019.
  1. Apr 5, 2019 at 12:28 PM
    tacomach2
    tacomach2 [OP] New Member
    Can anyone tell me what the wiper arm force should be, measured by a spring scale out at the blade attachment point? In the past few years my 2007 blades have increasingly started to skip and chatter. Trying different brands of blades has not helped, as have neither Windex, RainX, etc., etc. . I found a small coil spring in my shop and attached it to the built-in wiper arm spring and, bingo, wiping problem cured! Obviously the original springs have fatigued over time. Not being in the mood to spend $80+ (!) for one new wiper arm, I am thinking of getting used arms from a wrecking yard, but if the springs in used ones are just as weak, I will be throwing good money after bad. If I know the minimum arm force, I can take a spring scale with me to test used wiper arms before I buy. Can anyone can help with this?
  2. Apr 5, 2019 at 12:38 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why not just replace the wiper arm and be done? I highly doubt anybody has checked the strength on the wiper arm spring...
    bought a 30k dollar truck, can’t spend the 80 bucks for a new wiper arm...
    HoulaHauler, Blockhead and ace96 like this.
  3. Apr 5, 2019 at 12:54 PM
    Muddinfun
    Muddinfun Well-Known Member
    More than likely they only chatter in 1 direction. To work properly, the rubber needs to flop and drag. Not scrape like pushing a snow shovel. Turn the wipers on and shut the key off mid stroke in each direction. If it's not flopping, take a Crescent wrench, put it on the arm near the blade and twist it slightly so that the blades will flop.
    PNW/TRD Steve likes this.
  4. Apr 5, 2019 at 12:58 PM
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Nothing wrong with reusing parts and saving money. I would look at Muddinfun's suggestion first.
  5. Apr 5, 2019 at 3:14 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Mine chattered on the drivers side - I tried to cheap out with RainX but NG - Went with Bosh Icon $20 done no more problem. I don't get the $80 price - Bosh is the best you can buy as far as I know. What did I miss.
  6. Apr 5, 2019 at 7:37 PM
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    He is talking about replacing the whole arms, not just the blades.
  7. Apr 5, 2019 at 9:12 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    This seems like a weird problem to have? The wiper arm spring does stretch a bit during use (to account for the curve of the glass), but for it to wear out? Do you live in an area where it frequently rains?
  8. Apr 6, 2019 at 1:15 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Why not pull your spring and use the spring scale to see what it is? Since it's too weak you'll know the minimum to test for at the junk yard.
    Consider posting a WTB in the For Sale forum, maybe someone has them laying around they will sell for cheap.
  9. Apr 6, 2019 at 2:29 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
