Wiper arm replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Mar 18, 2011.
  1. Mar 18, 2011 at 8:12 PM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    My washer button hasn't worked since i bought the truck. Ive heard you have to remove the wiper arms. So that involves removing the airbag and all that jazz. Has anyone ever done it? If so, how hard is it and what do you have to be careful with?
  2. Mar 19, 2011 at 5:47 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Does the button not work or just the washer system, have you applied power right at the pump to check?
  3. Mar 19, 2011 at 11:37 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yes i have done everything. I know its the button because i took apart the steering column covers and i was playing with the wire that goes into the arm. Got it to work for a minute but as soon as i put the wiper in the fast position, it stopped working.
