Wiper blade arm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NBourque, Mar 30, 2023.
  1. Mar 30, 2023 at 5:09 AM
    NBourque
    NBourque [OP] Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Lately I’ve been having issues with my drivers side wiper blade arm. The nut holding the arm seems to get loose and it won’t swing the blade across the windshield. It’ll just get stuck near the base of the windshield. I’ve tried tightening the nut but it doesn’t seem to work after a day or two. Any ideas?
  2. Mar 30, 2023 at 5:13 AM
    Tacoma Mike
    Southern Maine
    You need to remove the arm and clean all the teeth on the pivot with a scribe or similar.
    If you wait too long you will wear out the center of the arm and it will never tighten.
    Cranking on the bolt will do nothing.
    wi_taco, Dm93 and Bagman like this.
  3. Mar 30, 2023 at 7:27 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Thanks for the info! Easy to disassemble and clean?
  4. Mar 30, 2023 at 7:35 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  5. Mar 30, 2023 at 7:35 AM
    Tacoma Mike
    Southern Maine
    Yeah. Scale of 1 to 10 it’s a .5…
    Just make sure you cycle the wipers to park before you lock it down.
    And stop trying to turn on the wipers with a shit ton of snow and or frozen blades..
    SR-71A likes this.
  6. Mar 30, 2023 at 7:36 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Take off nut, give a slight tap with heal of hand at the joint should pop right off
    Clean those grooves and one’s on the arm
  7. Mar 30, 2023 at 7:40 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Set to park? Haha. Thanks guys
  8. Mar 30, 2023 at 7:58 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Putting the arm back on a spline off from its original alignment the first time is kinda easy to do if you're not used to it. It can help to take a photo before you start of the wiper arms at their rest (parked) position to make sure you get them in the original position.
    Note that new arms come with no splines cut in the mounting hole. They're cut by the post the first time its mounted.
    The splines on the drive stud are kind of small, so it doesn't take much crud in them to interfere with the arm fit. I use a fine/soft wire brush to clean mine. It's a relatively delicate part one wants to take care of. Better to replace an arm if needed than get into the wiper drive transmission.
  9. Mar 30, 2023 at 9:46 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    If the splines are worn is there any way to get the arm in?
  10. Mar 30, 2023 at 9:48 AM
    Tacoma Mike
    Southern Maine
    Splines won’t be worn.
    It shaves the aluminum pocket before it ruins the splines
  11. Apr 2, 2023 at 11:57 PM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Cleaned the splines and all seems to be working fine now. Thanks guys.
    Tacoma Mike likes this.
