WIPER MOTOR
Discussion in '1st Gen. Tacomas (1995-2004)' started by Newby, Jun 3, 2013.
  1. Jun 3, 2013 at 6:12 AM
    Newby
    Newby [OP] Well-Known Member
    North Carolina
    Hello,
    I got a 96 Toyota Tacoma sr5 v6 4x4. The problem is the wiper does not work. I tested the water and it came out to the windshield, but the wiper does not wash the windshield. I checked all of the fuses and everyone is fine. I doubt that the problem might be the wiper switch because the water comes out fine.
    I went to buy a used wiper motor and a wiper switch from the junk yard. First, I tried to replace the wiper motor and I already got the four bolts which holds the wiper motor to the firewall but I could not get it out because the pin at the back of the wiper motor connect to the somewhere inside the firewall. How can I take it out? Please give me an idea if you know. Also how to replace the wiper switch too.
    Thanks.
  2. Jun 6, 2013 at 8:09 AM
    Newby
    North Carolina
    Never mind. I got it Replaced.
  3. Sep 23, 2013 at 5:16 PM
    heart2fight
    heart2fight New Member
    Bossier City, La
    03 Double Cab PreRunner
    how did you get it out? Im in the exact same boat
  4. Sep 30, 2013 at 10:05 AM
    Newby
    North Carolina
    Just follow the steps below:
    Removing:
    1. Remove your wiper arms both side.
    2. Try to slowly pull the pump out.
    3. Use a little/medium flat screwdriver to push the rubber which cover/connects to the pin of the pump off. That is!!
    Note: Installing the new pump is just reversing the steps above only.
