Wipers keep on wiping!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by souchmk, May 22, 2012.
  1. May 22, 2012 at 2:07 PM
    souchmk
    souchmk [OP] New Member
    Gerry
    Suffolk, Va.
    Tacoma PreRunner
    Trailer hitch
    Hey all,
    I have a 2010 Tacoma 4.0 Access. I am having issues with the wipers. When the wipers are on for an extended period of time, and then shift the switch to intermitten mode, it continues to operate in normal mode. I am in the process of taking it into the dealership to have them check it out. Obviously they won't do it when you want it to, but has anyone else had the same issue, and if so what was the remedy? Thanks!!
  2. May 22, 2012 at 2:08 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Might be a dumb question but is it on the fastest intermittent setting?
  3. May 23, 2012 at 5:39 AM
    souchmk
    Gerry
    Suffolk, Va.
    Tacoma PreRunner
    Trailer hitch
    I have set the intermitten mode to the lowest setting, and it still continues to operate as though it was in normal wiping speed, and yes I have put the wiper switch through all the paces, and it still does the same thing!!
  4. May 23, 2012 at 8:51 AM
    Skycam3
    Skycam3 Waiting to see...
    Tony
    Nashville
    2012 Tacoma DCLB TRD Sport 4x4
    Flyzeye, Redline hood struts, Demello Sliders, Pelly wrap around light bar, Roll-N-Lock tonneau cover, 2 Hella 700FF, DIY LED light bar(10,000 lumes), LED bed lights.
    Sounds like a bad switch...
  5. May 23, 2012 at 9:46 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I did notice a difference in my '10 from my '05 intermittent dial... They are opposite of each other. The fastest rate dial setting on my '05 is the slowest on my '10!
  6. May 23, 2012 at 10:14 AM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    i make mine do that on purpose, it bends the blade so that on the return to home sweep, it clears the most amount of water without streaking. if they didnt come up a little after returning to the home position, the up stroke is clean and clear from streaks, but the down stroke is streaky. im super anal about little things like that.
  7. May 23, 2012 at 10:16 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    sounds like a problem for warranty man!
    i bet the switch went bad.
  8. May 23, 2012 at 10:22 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    I have had this happen to me many times. a couple of times I have even canceled my plans to go straight to the dealership but right before I get there it stops doing it. It drives me absolutely crazy. One thing I have noticed that tells me when it is going to happen is when you shut the wipers off when they drop down to the bottom they actually lift back up about an inch to 2 inches.
  9. May 23, 2012 at 11:18 AM
    03DBLCABTACO
    03DBLCABTACO Well-Known Member
    Dan
    Tomball TX
    Cavalry Blue 2019 TRD OFF-ROAD 4X4
    It happens to mine also 2010 dblcab. Seems to only happen when it rains. Out of warranty for me. Let us know of you hear of a fix.
  10. May 23, 2012 at 12:11 PM
    mclovin
    mclovin chicka chicka, yeah!
    Biloxi
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    same on my '12. kind of takes some getting used to
  11. May 23, 2012 at 8:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My 2012 Ext cab is the same ( backwards )... It works fine though.
