Wipers slipping out of position
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FN TACO, Oct 17, 2020.
  1. Oct 17, 2020 at 9:36 AM
    FN TACO
    FN TACO [OP] New Member
    19 TRD
    3”lift tinted windows, KO2 tires and same size as stock.
    Anyone have wipers slip out of position after wiping 3-4 inches of snow? 2019 Tacoma
  2. Oct 17, 2020 at 9:48 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Sounds like you have too heavy a load on the arms.
  3. Oct 17, 2020 at 9:54 AM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    This.
    Best not to use the wipers to move anything more than snow falling as you're driving just in case they're frozen or the weight is too great. Keep them up when parked and brush all the snow away before using them. How far out of position are they?
    RedWings44 likes this.
  4. Oct 17, 2020 at 9:58 AM
    FN TACO
    19 TRD
    They were about 10 inches off. I moved them back by hand and they work fine. Lesson learned
  5. Oct 17, 2020 at 10:03 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    The wiper arm has little teeth that go into splines that are on the wiper transmission. The arms are softer than the transmission is so when they slip like that you only need to buy new arms.
    But, yea as the other said, wipers are not designed to clear snow, they are designed to wipe away small amounts of liquids. Always clear anything over 1/8inch by hand then use wipers to clear the dusted snow.
    If they slip again, you will probably need to get new arms or crank down the bolts that hold the arms on (not too tight though, if you break it a new wiper transmission is much more expensive than new arms)
    tcjacado, whatstcp and GarlicFarts like this.
  6. Oct 18, 2020 at 8:47 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    Great info my wife has a civic doing the same thing, THANKS !!!!!
  7. Oct 18, 2020 at 9:07 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    My problem with wipers is that that the outside perimeter does not get a clean wipe, like a 2" wide arc. Replaced wipers, not fixed.
    tcjacado likes this.
  8. Oct 18, 2020 at 9:08 AM
    5nahalf
    Erik
    Minnesota
    Lube the joints on the wiper arms (not the blades, but the spring joint down at the bottom of the arm.)
    Winch[QUOTED] likes this.
  9. Oct 18, 2020 at 9:09 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sounds like my first night after my wedding :oops:
  10. Oct 18, 2020 at 9:48 AM
    TNFirefighter29
    TNFirefighter29 Well-Known Member
    Tennessee
    2020 Magnetic Grey Tacoma TRD
    After doing this I am surprised they still work. I turned on wipers didn't notice they were frozen to the windshield, $200 mistake.
    whatstcp likes this.
  11. Oct 18, 2020 at 10:22 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Get some better quality wipers the oem ones are shit .
    GarlicFarts and RedWings44 like this.
  12. Oct 18, 2020 at 12:02 PM
    T4RFTMFW
    Did you even read the thread?
    Toyko Joe and tcjacado like this.
  13. Oct 18, 2020 at 12:04 PM
    Tacoma Mike
    Southern Maine
    If you moved them back by hand then it’s not fixed..
    GSRON, Boghog1 and tcjacado like this.
  14. Oct 18, 2020 at 12:07 PM
    tcjacado
    tcjacado Well-Known Member
    He is right though. On my 17, the blades are crap, its a full smear almost, not wipe clean and using more washer fluid does not help on bit. Good thing I live in southern California and rarely need them.:fistbump:
  15. Oct 18, 2020 at 12:13 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :facepalm:
    Skydvrr likes this.
  16. Oct 18, 2020 at 12:16 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What blades are you using?
  17. Oct 18, 2020 at 12:21 PM
    RedWings44
    Michigan
    I don't know why wiper defrosters aren't standard. I had them on a 2003 Caravan, but the F150 only has them on higher trims and most cars don't have them at all.
    usmc2msu likes this.
  18. Oct 18, 2020 at 12:22 PM
    RedWings44
    Michigan
    He may be referring to the post about the outer 2" not wiping clear and forgot to hit the quote button.
  19. Oct 18, 2020 at 12:59 PM
    Winch
    2019 TRD OR MT V6
    None yet
    I apologize for hijacking this thread.
  20. Oct 18, 2020 at 1:02 PM
    GOTSAND?18
    stock
    Oem ones are shit I use rain X latitude blades work great in the rain snow doesn’t leave streaks across your windshield like the oem ones .
