wire color help
Discussion in 'Audio & Video' started by T.J., Dec 31, 2010.
  1. Dec 31, 2010 at 8:51 AM
    T.J.
    T.J. [OP] Taco Jockey
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    Century Truck Topper, custom made "Batman" center caps, satoshi mod (Thanks tons, TY!), Hella 500 grille lights, painted radio, climate control, and radio surround panels, painted rear bumper
    Need to know what color wire is used to power the OEM, non-JBL head unit in the harness. Search efforts have not helped, but it's likely because I'm not using the right terminology.
  2. Dec 31, 2010 at 11:59 AM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    Are you replacing a head unit or just trying to use this lead for something weird? If you are replacing the unit you should use a wiring harness and those come with instructions/labels.
  3. Dec 31, 2010 at 8:29 PM
    T.J.
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    I have a Zune adapter that calls for tapping into the power wire (to charge the Zune while plugged in). It's the only thing I have not done when installing the kit. Since I can't seem to get the kit to work, I figured it must have something to do with this. Otherwise, its a pretty straight-forward install.
  4. Dec 31, 2010 at 8:35 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Your constant power wire color is blue/yellow. The ignition switch power is gray. I got this from a wiring diagram on mitchell.com
  5. Dec 31, 2010 at 8:39 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
  6. Dec 31, 2010 at 8:40 PM
    NelsonTacoma
    Tucson, AZ
  7. Dec 31, 2010 at 8:53 PM
    T.J.
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    Excellent!! :cheers:
    Happy New Year!
  8. Jan 6, 2011 at 3:52 PM
    toyowarrior
    toyowarrior New Member
    i have a 2003 tacoma ext cab. im trying to install a indash navi. im trying to find the vss wire. any help would be greatly appreciated. thanks guys
  9. Jan 6, 2011 at 7:56 PM
    NelsonTacoma
    Tucson, AZ
    From the wiring diagram I have it looks like the VSS has 2 wires, yellow/red(+) and white/red (-). It goes straight to the ECM which is located behind the right side of the dash, in behind the glove compartment. If you find the ECM it looks like the wires are in pins 22 & 23.
    Edit: Welcome to TW.
