Wire Colors for Reverse Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3noir, Jun 22, 2022.
  1. Jun 22, 2022 at 7:14 AM
    3noir
    3noir [OP] New Member
    2007 Tacoma
    2007 Tacoma. I'm connecting a rear camera and need to determine which wires are pos and ground on the reverse light.
    I'm pretty sure from reading elsewhere that
    red/blue stripe = pos
    white/black stripe = ground
    Can anyone verify this?
  2. Jun 22, 2022 at 7:21 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Assuming you have to cut them to connect up your camera, cut the cut the RB and then meter to ground; if you get 12v when the truck is in reverse, that's '+' if not, it's '-'. FWIW, I'm certain you are correct.
  3. Jun 22, 2022 at 7:26 AM
    3noir
    2007 Tacoma
    I was planning to use the quick connects that pinch through the insulation
  4. Jun 22, 2022 at 7:28 AM
    tirediron
    Don't!! Those Scotchlocks are junk. Take the extra five minutes, cut, solder, and cover using adhesive-lined heatshrink. That will last the life of the truck.
    Dm93 likes this.
  5. Jun 22, 2022 at 10:32 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My diagrams show it as a Red/White wire for +
    And White/Black for -
    You can check it yourself, but you’ll need to be in reverse.
    You can use the shift lock over-ride button if your an auto.
    Manual just put it in reverse.
    Dm93 likes this.
  6. Jun 22, 2022 at 10:40 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    White/Black is pretty much exclusively used for ground on Toyota, for 07 it shows the reverse power wire being Red/White.
    I agree on not using scotch lock wire taps, they are nothing but constant headaches with corrosion and bad connections.
  7. Jun 22, 2022 at 11:24 AM
    3noir
    2007 Tacoma
    Thanks. Are Posi-Tap connectors any better?
  8. Jun 22, 2022 at 3:48 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Maybe but any kind of wiring connection that isn't sealed on the exterior of a vehicle will corrode, if you aren't in an area where roads are salted you may be able to get away with it but anywhere that has salted roads in the winter you likely would be lucky to get 1 year out of it before the wire corrodes to nothing.
