Wire gauge?
Discussion in 'Lighting' started by pruchai, Sep 19, 2014.
  1. Sep 19, 2014 at 1:33 PM
    pruchai
    pruchai [OP] KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    I am planning on installing a BlueSea fuse block sometime next week and first thing I am going to hook up to it is my topper light and possibly some additional 12V and USB outlets in the bed. So that would probably be 12-15 feet of wire.
    I am thinking 12ga wire. Overkill or just good enough?
  2. Sep 19, 2014 at 1:35 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    14 gauge is probably fine but bigger is okay.
  3. Sep 19, 2014 at 1:40 PM
    pruchai
    pruchai [OP] KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    sweet, thanks!
  4. Sep 19, 2014 at 3:39 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    I would go even thicker. Depending on how many things you plan on running. If it's smaller accessories then you don't need much. I am using the box for led light bars so I ran I think it was 4 ga wire just to be safe and not do it again. I would go 10ga for accessories. The main power wire to battery that is.
  5. Sep 20, 2014 at 9:28 PM
    skygear
    skygear                    
    If you ever want to run a fridge back there or anything like an inverter. I would recommend, at a minimum 8 gauge. More like 4 gauge.
    What I did for the rear was run 2/0 gauge to the rear to a distribution block, then shorter leads to the accessories I want to run.
    I like to think ahead and only do things once. ;)
