Wire harness - what is it for?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mmatheny, Aug 27, 2008.
  1. Aug 27, 2008 at 2:36 PM
    mmatheny
    mmatheny [OP] Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    I pried off the cover below my right inboard A/C vent and there was a small 2 pin cable there - is that for the passenger SRS disable switch? If so, can I hook a switch up to it and it will work?
    I have an '08 DC, which doesn't come with an SRS disable switch.
  2. Aug 27, 2008 at 2:47 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Picture?
    -Dan
  3. Aug 27, 2008 at 2:57 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    if ur talking about the panel just right of the steering wheel below that vent, its for the 4x4 switch. i dont think there is a passenger side airbag switch since the buckets have sensors in them to turn the airbag on or off, depending on weight in the seat
  4. Aug 27, 2008 at 3:18 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Nope, talking about the semi-rectangular panel below the A/C vent to the right of the radio. I perused the wiring diagrams, but couldn't find it. On the bench seats there is a passenger SRS disable switch you operate with the key.
  5. Aug 28, 2008 at 12:26 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Here's a pic.
  6. Aug 28, 2008 at 12:38 PM
    Oscar 319
    Oscar 319 Senior Citizen
    Utah
    2007 TRD 4WD Double Cab
    I may be wrong on this, but I believe that is for the switch for the optional, roof mounted TOW missile launcher or remote operated M2.
  7. Aug 28, 2008 at 12:48 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    I took that off - kept getting tangled in the tree in my driveway.
  8. Aug 28, 2008 at 5:58 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Knocked mine off on a freeway overpass.... Toyota should really work on that!!
  9. Aug 28, 2008 at 6:30 PM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    it is for a switch to disable the airbag on the passenger side; double cabs don't have this as you would never need to put a rear facing child seat in the front. I've noticed that the seat in my DC has a weight sensor in it. My 11 year old daughter is big enough that it will show it activated; my 9 year old son is light enough that it shows off when he rides in the seat.
    Oh ya, if you put it in 4 low, it is disabled no matter who is sitting in the seat from my recollection.
    I guess I do like the automatic part of this feature.
  10. Aug 28, 2008 at 6:35 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Bingo^^^...All the cabs come pre-wired,but the DC's don't get the key on/off.
  11. Aug 28, 2008 at 6:35 PM
    lakewoodbilly
    Bill
    Lakewood, CO
    One more thing - I took my cover off, drilled a hole in it, ran my satellite radio wires through it and mounted my Siruis Sportster 5 using a mount from an XM Roady and the very strong two way sticky tape; it as good / better than a professional install job that any of the 6 places I checked in Raleigh offered to do. Ha HA
    I bought a replacement cover from toyota of dallas in case I decide to remove that radio and go with something different or If I decide to trade it in or sell it, I can take my radio out and put the new replacement cover on it. ~$10 bucks from them; retails for ~$20.
  12. Aug 28, 2008 at 11:54 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    LMAO that was funny man...
  13. Aug 29, 2008 at 4:06 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Do you think it is live- i.e. could I hook a switch to it to turn it off so my dog doesn't keep tripping the SRS system to "buckle up"?
  14. Aug 29, 2008 at 4:47 PM
    lakewoodbilly
    Bill
    Lakewood, CO
    I don't know. Assuming there are just the two wires, you could jumper the pins to see what the affect is since that is all that the switch would be able to do anyway.
    You should be able to order the actual factory switch and plate. Check out trdparts4u.com. You'll want to look for a switch for a regular cab or access cab.
  15. Aug 29, 2008 at 6:22 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    I kinda think just adding a switch would not do the trick, as it is just too simple. I have a reg cab with the switch, and if you turn it off and the seat is occupied the light will flash to tell you to turn it on, but with no audible warnings. As for the too simple part; most vehicles would require the hand held scan tool be used to enable the new parameters, and in other manufacturers where people have tried it, the ECM/BCM will not accept the switch, "knowing" that the vehicle in question does not offer the switch. That may or may not be the case here though. As for jumping the switch, I would be careful without a schematic as it may not be a simple bridge; the switch may have a resistance value in one or both settings. If I get a chance sat or sun, I will pop my switch out and poke at it with my Fluke a bit. I have heard in the past that the switches the manufacturers offer as the cuttoff switch offered as the one the fed's allow when a waiver is obtained, is not the same one used in OE applications where the vehicle has the switch due to no backseat, most likely just to make things more difficult, as they would probably get the blame for a non functioning air bag down the road.
  16. Aug 31, 2008 at 3:37 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Did you get a chance to look yet?
  17. Aug 31, 2008 at 5:07 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yeah i had to get rid of mine. i scared toom many kids with it. plus i accidentally shot a good sized hole through about 3 cars
  18. Aug 31, 2008 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If that was a real option:
    A. I would have it
    B. I would be in jail from useing it
    C. I would have fled the country and be liveing in the Bahamas from useing it
    D. Hmmm......I live near Dillon Areo. I wonder if they do Installs.....:rolleyes:
  19. Aug 31, 2008 at 5:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Aug 31, 2008 at 5:47 PM
    squad314
    Marc
    Holy Shit that's a pile 'o brass.^^^:eek:
