Wire One Rocker Switch to control three separate harnesses
Discussion in 'Technical Chat' started by Nick05Tacoma, May 10, 2017.
  1. May 10, 2017 at 7:57 PM
    Nick05Tacoma
    Nick05Tacoma [OP] Member
    Nick
    2005 Tacoma Access Cab
    How would I wire one rocker switch to control three to five harnesses/lights already controlled by individual switches?
    Specifically 4 pods, 1 52 inch double row, 1 20 inch double row.
    Thanks!
    -05tacoma
  2. May 10, 2017 at 8:02 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Relays.
    I am assuming you want a master switch to kill power (or supply) all at once. Wire one relay with the output supplying everything else. Determine your load and size your relay to max load and fuse accordingly.
  3. May 13, 2017 at 9:37 AM
    Nick05Tacoma
    Nick
    Does it make a difference if there are relays in the harness already? Anyone have a wiring diagram for this sort of thing?
  4. May 13, 2017 at 10:03 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Couldn't find a diagram showing multiple relays, so I'll reference the one below. What you need to do is connect the "load" (output) of your single switch to the "86" (trigger) input on each of your relays. It can be a pain in the ass because there is no standardization of wire colors or relay pin numbering in the aftermarket. Be patient and label the wires before you start cutting and splicing.
  5. May 13, 2017 at 10:13 AM
    Nick05Tacoma
    Nick
    Awesome thank you!
    EDDO[QUOTED] likes this.
  6. May 13, 2017 at 10:17 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    You'll be cursing soon if your experience is anything like mine working on @tyfoon11 truck. :D
  7. May 13, 2017 at 11:20 AM
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    lol, works now tho!
    :thumbsup:
