Wire that's only hot when engine is running?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, Apr 4, 2013.
  1. Apr 4, 2013 at 1:39 PM
    memario1214
    memario1214 [OP] Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    I am looking to tap into a wire under the hood that is only hot when the engine is running. I know that the foglight anytime mod comes pretty close, but I do not want the wire hot when I am in accessory mode (first click of the key). I could go prodding around, and will likely test it anyway, but I was just wondering if anyone knew off the top of their head.
  2. Apr 4, 2013 at 1:45 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    I have had this question asked before from someone a while back. I cannot find and wire that is 12V hot only with engine running. The 12V hot wires are either Key off, key accessory, key on, key cranking.
  3. Apr 4, 2013 at 1:46 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    The fuse i used is only hot on the second click when turning the key and when the engine is running, not hot on the first click, is that what you are looking for?
  4. Apr 4, 2013 at 1:53 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Well there is one I know of... But it is in the cab. Blue wire with a yellow stripe front and center. I would really like to pull the power from under the hood though if I could.
    Much closer to what I am looking for yes :D watcha got for me?
  5. Apr 4, 2013 at 1:58 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Well i kinda skimmed through your post and didn't read the under the hood part lol, its in the fuse box behind the coin tray to left of the steering wheel, middle row 2nd one in from the left, i used it to power my switch for my LED light bar that is mounted exactly like yours :D, pictures to make it easier
  6. Apr 4, 2013 at 2:13 PM
    moondeath
    moondeath Tyrannical leaders use 'Alternative Facts'
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    What did you use in that picture to tap into your fuse?
  7. Apr 4, 2013 at 2:16 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    A mini fuse tap lol, or add a circuit it might be called, i am a complete wiring newb, i got some great pointers from a member on here
    Ran that to my switch, switch to a relay, then relay to my light
  8. Apr 4, 2013 at 3:07 PM
    moondeath
    Pa, Carlisle
    Thats pretty nifty. Can't say that I've ever seen one of those before.
  9. Apr 5, 2013 at 7:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    Interesting. Nice to know that there is a 12V hot with engine running power source. It's not live with just the key in the on position?
  10. Apr 5, 2013 at 11:09 AM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    I will make a video of my setup here soon enough, but the one I tapped (blue w/ yellow stripe) is in fact hot with the key in the on position... However, in my struggles to find a suitable wire I believe I have found one. I have the DTRL lights and there is a plug that goes into the flasher box, the one that actually makes the blinker click sound. Pin 10 comes hot about 2 seconds after the truck starts up and is not hot in the on position. It has to be the control for the DTRL, but it seems to be the only thing I could find... :notsure:
  11. Apr 5, 2013 at 11:12 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Might I ask what you are planning to do? Seems interesting.
  12. Apr 5, 2013 at 11:13 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You should be able to get them at any auto parts store for a couple bucks. If you use them, make sure you install them in the correct orientation, especially if you run a heavy load off of them.
    Also, I believe the picture Evan showed is the fuse panel in the dash, not under the hood. I was not able to find one under the hood that does what the OP is asking. I ended up using the A/C fan fuse under the hood since I always have my fan on anyways. Not exactly the best method, but it works.
  13. Apr 5, 2013 at 11:28 AM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Keep an eye on my build... It will be updated in the next couple days :cool:
    Yeah I didn't find what I was looking for either under the hood. I did the foglight anytime while I was under there though lol. I ended up drawing from the panel that is in the cab for this project as well
  14. Apr 5, 2013 at 12:31 PM
    BamaToy1997
    Bill
    Navarre, FL
    Ah, Ok. The OP was talking about a hot wire only when the engine was actually RUNNING, as I understood it, not with it just on. Perhaps I misunderstood him.
  15. Apr 5, 2013 at 12:37 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    I am the OP... and that's what I was talking about. I changed my mind midway through
  16. Apr 5, 2013 at 5:48 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Its not live when the key is in the AAC position (first click) it is live in the on position (second click) so the fuse i used isnt really what the OP was looking for, just thought it might help.
