Wired up LEDs tonight and worried about...
Discussion in 'Lighting' started by Danactive, May 20, 2016.
  1. May 20, 2016 at 8:59 PM
    Danactive
    Danactive [OP] Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    just wired up a 50", 30" and 2 ditch pods tonight with all separate relays and harnesses. i noticed after about 15 minutes of them all being on the relays started to get warm... not hot like melting or fire could occur but definitely warmer than when the lights are off... i checked to maybe see if it was maybe the engine heating up around the area where the relays are mounted and the entire area was cool to the touch... is it normal for the relays to get warm? any help would be greatly appreciated!
  2. May 20, 2016 at 9:05 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    what wattage/amperage are your lights? What guage wire are you using? Are they fused? Is your relay rated for the wattage your consuming? The relays will get slightly warm because of the coils inside but shouldn't be "hot"
    Danactive[OP] and ChadsPride like this.
  3. May 20, 2016 at 9:05 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    I don't have a clue, subd for answers
  4. May 20, 2016 at 9:38 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Pretty sure mine get pretty warm too iirc. And if I can remember I'll check them tonight when I get home because I use mine every night for a good while. I think it's a normal thing for them to get a little warm. But if they're hot, then you might have issues. Either a low quality relay or maybe wire gauge that is playing a part.
  5. May 20, 2016 at 10:58 PM
    NightProwler
    Harlan
    Maricopa, Az
    And yeah this pretty much sums it all up. Guess I overlooked this post. Ha. All these things Will play a part in the efficiency of the circuit and should be checked into. Also, if you are using cheap premade China harnesses, I'd check the wires to see if they're getting hot as well. They often have low quality components. I always make my own with proper gauge wire. Still on the lookout myself for some high quality relays. I used some from AutoZone and they work, but aren't waterproof. As well as some from theretrofitsource. Which those seem to be better quality, but again are not waterproof. I've seen some nice ones somewhere that were waterproof but can't seem to find them again for the death of me. As well as some better quality wire.. Not too concerned with my rats nest of wiring and relays under the hood right now. But I will eventually be redoing it all with the best stuff I can find.
    Danactive[OP] likes this.
  6. May 21, 2016 at 6:52 AM
    Danactive
    Dan
    Upstate New York
    great info guys... i got the wire harneses with my light bars from caliraised... from what i can tell the wire gauge varied on two of the harnesses but seemed like quality harnesses and relays. i could have very well over thought it and paranoid myself enough to justify asking this question but i figured better ask some of the forum guys before i melt down my engine bay.
  7. May 21, 2016 at 6:57 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Probably fine... IIRC, take the wattage and divide by 12....make sure your amps are not too high for each relay.
    Also there are tables out there which state what gauge wire it should be based on load and length of the runs...double check that too if you have long runs.
  8. May 21, 2016 at 12:50 PM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I hard a hard time finding a waterproof relay that was rated for 40 amps so I just took some anti corrosI've grease and coated the pins. Haven't had any problems
    ChadsPride likes this.
