Wired -> Wireless CarPlay Adaptor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GigG45, Jun 29, 2021.
  1. Jun 29, 2021 at 1:07 PM
    GigG45
    GigG45 [OP] Active Member
    Gig
    Southern Arkansas
    2020 Tacoma TRD Sport
    Trunk Lock.
  2. Jun 29, 2021 at 3:33 PM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    No experience but commenting in case anyone has a recommendation. $100 seems steep for it though, I'll just keep plugging in for that price.
  3. Jun 30, 2021 at 8:15 AM
    GigG45
    Gig
    Southern Arkansas
    Trunk Lock.
    Once you've gotten used to just getting in the car and it being connected for the last 2 years has spoiled me.
    $100 is about the difference between a Kenwood with wireless and a wired one.
  4. Jun 30, 2021 at 9:25 AM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    https://cplay2air.com has been working flawlessly for me. Combined with the wireless charger base no more fricken wires all over the place for me.
    mardis928, Bob1971 and GigG45[OP] like this.
  5. Jun 30, 2021 at 9:57 AM
    Direktor
    Direktor New Member
    2021 Tacoma Trail Edition
    I got the Amazon one at $109. It's working fine with an iPhone 12.
    More reliable than the Chinese headhunt I have in my work van with wireless CarPlay...which connects only most of the time.
    GigG45[OP] likes this.
  6. Jun 30, 2021 at 8:22 PM
    sc20
    sc20 New Member
    2021 Voodoo Blue Tacoma TRD Sport
    I use this one in my Tacoma and Grand Cherokee. Works great. Occasionally, I need to unplug and plug it back in for it to reconnect. Well worth it to me.
    CarlinKit 2.0 Wireless CarPlay Adapter for Volkswagen 2016 2017 2018 2019 2020 2022 with Factory Wired CarPlay, Type C Design, Online Upgrade Adapter, iOS14, Convert Factory Wired to Wireless CarPlay https://www.amazon.com/dp/B08G1DR2RS/ref=cm_sw_r_cp_api_glt_fabc_RY32XBW3QFPKEGNQ0ATG?_encoding=UTF8
  7. Aug 23, 2021 at 1:44 PM
    GigG45
    Gig
    Southern Arkansas
    Trunk Lock.
    I finally got around to ordering and installing this one https://www.amazon.com/dp/B08P1GWQDB?ref=ppx_yo2_dt_b_product_details
    It rocks. It links up to my iPhone 12 faster than the Kenwood I had in my Corvette. After I start the Taco and by the time I've put on my sunglasses and seatbelt I have CarPlay.
    5 Stars *****.
    Now I have a question. Has anyone taken their radio out of the truck and seen the back of it? I'm wondering if there is a USB port on the back that goes to the USB port on the dash. If so I'm going to mount it behind the head unit and figure a way to run a power only USB port to the dash.
  8. Aug 23, 2021 at 1:57 PM
    Direktor
    Direktor New Member
    it does go to the back of the head unit, but it is a very specialized, non standard connector. People have had better luck adapting the harness as it goes into the back of the CarPlay USB port there.
    The connectors are avail, but generally on the other end of the harness is what you’re able to find. There’s a thread on here somewhere about it, people wanted to swap the CarPlay USB into the console and the power-only port to the dash.
    hotrod 15 likes this.
  9. Aug 23, 2021 at 1:59 PM
    Clark.W.Griswold
    Clark.W.Griswold Well-Known Member
    Sparky
    2024 Ford Ranger Raptor
    Would this work for those that don't have the factory CarPlay, but have the BeatSonic CarPlay unit? Anyone tried that yet?
  10. Aug 23, 2021 at 2:10 PM
    MtRainier
    MtRainier Well-Known Member
    Randy
    Seattle, WA
    2021 Super White TRD Off-Road 4X4
    SnuggleTruck likes this.
  11. Aug 23, 2021 at 2:17 PM
    lossgenius
    lossgenius Active Member
    2021 Tacoma TRD OR Magnetic Gray
    Work in Progress...
    I have this also but my GPS is rarely accurate or just stops working... I have went back to wired but would really be interested in a wireless adapter that works...
  12. Aug 23, 2021 at 2:36 PM
    sc20
    sc20 New Member
    I wouldn’t do that. You need a way to turn it on and off (plug and unplug it) when it malfunctions or just doesn’t want to cooperate. At least a couple times per week, I need to unplug and plug mine back in to restart it. I just used some double sided tape and stuck it right there out of sight and blends in with the dash. Pretty much only see the plug and a bit of the little wire.
    GigG45[QUOTED][OP] likes this.
  13. Aug 24, 2021 at 2:06 PM
    GigG45
    Gig
    Southern Arkansas
    Trunk Lock.
    I had not thought of that. I should have seeing as I often had to turn the Kenwood I had on and off to get the CarPlay to work.
    I think what I'll do is tape it up somewhere I can use the USB port that is on the other end.
  14. Aug 24, 2021 at 2:15 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I put a 6600 in and that fixed the wireless, the volume and the speakers. Expensive but damn does it sound good.
  15. Aug 25, 2021 at 8:12 AM
    GigG45
    Gig
    Southern Arkansas
    Trunk Lock.
    Do you mean the Totoya NAV isn't accurate or just stops working?
  16. Aug 25, 2021 at 10:24 AM
    lylefk
    lylefk Well-Known Member
    Maui, HI
    '21 4wd Cement Sport DCSB
    Nothing major
    Here you go, this is the cable to run. Works great. I went this route because I didn’t want the sound quality loss associated with wireless CarPlay.
    https://m.aliexpress.com/item/4000904194171.html?spm=a2g0n.productlist.0.0.46615e901YX1B0&browser_id=87af462015324b19aad383682cf8caf4&aff_trace_key=c03490c5fe6f4539b2cd7d653ff8b13d-1588527650388-03910-_sAe255&aff_platform=msite&m_page_id=qlbfki3pxocauiiy17b7e557e2620d7ff7b8174610&gclid=&_imgsrc_=ae01.alicdn.com/kf/Hd47f8663e9994627940bd2aa1930dc98I.jpg_640x640Q90.jpg
    05 4x4 and philth like this.
  17. Aug 25, 2021 at 4:54 PM
    jaro
    jaro Member
    2020 TRD Off-Road DCSB Magnetic Gray
    I have the c2playair one and it works pretty well. It does require me to unplug and plug it back in every so often when it stops working. But overall, it’s convenient if I have a short drive and don’t want to plug my phone into the cable.
  18. Aug 31, 2021 at 5:32 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So that plugs into the back of the head unit so you can move the port to the glove box correct? What do you do with the port under the climate controls?
  19. Aug 31, 2021 at 6:00 AM
    TacomaTrub
    TacomaTrub Member
    Dallas, Texas
    2020 Barcalona Red Tacoma Limited
    subscribing
  20. Aug 31, 2021 at 8:58 AM
    Crosbaugh
    Crosbaugh Well-Known Member
